P0011 & p0452 ss/tc 08
Old Jan 20, 2015 | 02:48 PM
low_k3y's Avatar
Ok guys, what are these... went to autozone, but highly dislike their scanners :P I know I did have MAP sensor light since then upgraded to 3 bar, least that codes gone. Computer was updated at ZZP.
What should I be lookin at or for? thanks!
Old Jan 20, 2015 | 02:55 PM
umrdyldo's Avatar
P0011 is most likely the intake cam position sensor. It's located on the left side of the top of the valve cover. Just to the left of the spark plugs. Intake is front.
P0452 from experience is a bad purge selenoid on the intake manifold.
Both can be replace with basic hand tools in a matter of minutes.
Sorry don't have location on hand. Let me make one for you.
Old Jan 20, 2015 | 03:08 PM
blueLNFftw's Avatar
evap is $9 shipped on ebay
Old Jan 20, 2015 | 03:11 PM
blueLNFftw's Avatar
http://www.ebay.com/itm/130427099639?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Jan 20, 2015 | 03:35 PM
exninja's Avatar
FYI, your arrow is pointing to the intake cam actuator solenoid, NOT the cam position sensor. I think you're right that the code refers to the solenoid and not the position sensor, but they are very different parts. You can check the solenoid with an ohmmeter. I have a used one for sale if you need.
Old Jan 20, 2015 | 03:37 PM
umrdyldo's Avatar
This is correct. The intake cam actuator solenoid that I show is what needs to be replaced. Good Catch.
Old Jan 22, 2015 | 06:52 PM
low_k3y's Avatar
How much for the part blueLNF? trying to tackle these CEL's :P
thanks for the input guys! awesome!
Old Jan 22, 2015 | 08:09 PM
umrdyldo's Avatar
Intake side selenoid on the left of my picture
VALVE ASM-CM/SHF POSN ACTR INT SOL 12628347 12646783 12655420
Purge Valve on the right side of my picture
New GM 12592015 Purge Valve | eBay
Jan 12, 2016 12:01 AM
camaromanss1992
Oct 1, 2015 10:51 PM
Sep 27, 2015 08:53 PM
metroplex
Sep 27, 2015 07:48 AM
TylerJHowell
Sep 21, 2015 06:47 PM
