P0016 Crankshaft Position
P0016 Crankshaft Position - Crankshaft Position Correlation Bank 1 Sensor A
Eny body seen that errer before?? My care spit out its 1st CEL the other day and thats what it told me.. when I fisrt saw the light I check my airfilter to find the rubber boot on the Injen airfilter was torn and I may hav been sucking Sh|t up the pipe... could that be the cause? |
may just be that the crankshaft position sensor needs to be relearned
Sounds like you should try a Crankcase Learn.
I have only seen this error on cars with improperly installed cams, or those that swap computers with another car. Weird that yours would throw a code like that. |
Ya I thought it was odd aswell.... I have no internal mods and allways go to the same dealer... Is there a way i can do the Crankase lear myself?
Originally Posted by FuzzzMan
(Post 1370975)
no you have to have the tech 2
should be a warrantee thing NO??
it should yes.
You guys are awsome... Thnks much...
OK cant get in till teusday AM.. and they couldn't tell me if it was safe to drive or not because they had no idea |
