P0106 code
my car just threw p0106 map sensor i searched and couldnt find anything. What could be causing it to throw this i think it make be the hose that connects my cai to the valve cover cause its starting to come apart and i need to repleace just curious as to what all of yall think thanks.
anybody ????????? 20 views and nobody knows what may have caused this other than what i have said |
From what im reading any intake vac leak will cause that code,So yes fix that hose and erase the code again and see what happens.
• The PCM detects that the MAP sensor signal is 25 kPa more than the calibrated estimate for more than 90 seconds. OR • The PCM detects that the MAP sensor signal is 45 kPa less than the calibrated estimate for more than 90 seconds. Inspect for the following conditions: • Any disconnected, damaged, or incorrectly routed vacuum hoses • Any damage or fractures to the manifold absolute pressure (MAP) sensor housing • A missing or damaged MAP sensor seal • Restrictions or debris in the MAP sensor vacuum port • An Intake manifold vacuum leak |
thank you so much man i figured thats what it was now i just need like 3 dollars to go get a piece of new hose which i should have tommorrow lol
