P0433 & p2229
Old Feb 13, 2010 | 09:10 PM
cobaltBlackss's Avatar
P0433 & p2229
I've been getting P0433 and P2229 and I can't figure it out. I've replaced my map sensor and still get the CEL and stumbling at idle. The car acts fine at WOT.
Old Feb 14, 2010 | 12:56 PM
Has anyone else had this problem?
Old Feb 14, 2010 | 01:05 PM
shadowfaxss's Avatar
Is it P0443......I don't see P0433
Old Feb 14, 2010 | 10:26 PM
Yeah, typo. P0443.
V-Day bump
Last edited by cobaltBlackss; Feb 14, 2010 at 10:26 PM. Reason: Automerged Doublepost
Old Feb 15, 2010 | 08:10 AM
Coblasts's Avatar
For the baro code check your wires and connector on it (Barometer sensor)could of been damaged some how.(Its between the SC and the rocker cover )
The other code is your evap cannister purge solenoid so I dont know why you thought changing the maf sensor would help ?
The baro and the evap purge valve are roughly located in the same area,you might have a pinched wire there somewhere or one rubbed through and is shorting take a good look and follow the wires back from the purge valve and the baro to the pcm and look carefully.
Old Feb 15, 2010 | 12:55 PM
The baro and the evap purge valve are roughly located in the same area,you might have a pinched wire there somewhere or onr rubbed through and is shorting take a good look and follow the wires back from the purge valve and the baro to the pcm and look carefully.
Based on the two codes I would have to agree that you have an issue with the wiring. Coblasts is right on the money.
Billig ss/sc
Jan 6, 2014 10:03 PM
rukkee
Jul 9, 2010 05:55 PM
cobaltBlackss
Jan 19, 2010 10:39 PM
matchhead
Sep 22, 2009 06:23 PM
rukkee
Sep 21, 2009 06:47 PM
