Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   Problems/Service/Maintenance (https://www.cobaltss.net/forums/problems-service-maintenance-69/)
-   -   passenger door wont open!!! (https://www.cobaltss.net/forums/problems-service-maintenance-69/passenger-door-wont-open-156607/)
Thorin Feb 19, 2009 03:51 PM
this week i tried to open my passenger door and it wont open... when i try the handle is look like nothing is atach to it... my lock is working
the same thing hapen to me last summer but it was on garanty... im not on the garanty anymore and i dont know how they open the door!
bshoe421 Feb 19, 2009 04:01 PM
try searching on here, im pretty sure i have seen a few threads about this.
https://www.cobaltss.net/forums/sear...archid=6049796
^^there you go hopefully this is some help
Thorin Feb 20, 2009 09:06 AM
the link dont work! :(
GSMiller Feb 20, 2009 09:10 AM
Will it not open from the inside of the car, outside, or both?
SSsteve Feb 20, 2009 09:10 AM
use a m-80 to open doors
Thorin Feb 20, 2009 04:05 PM
both!
m-80???
bshoe421 Feb 20, 2009 04:13 PM
my bad. click search then advanced then go to thread title only and type in "door wont open" and you'll get a ton of threads. hopefully that will help
BlilBT Feb 20, 2009 04:38 PM
This is caused by the latch not returning back to the set position! In the pic below you will see a I Hook with the cable attached, The I Hook isn't returning to the up position & stopping the handles from working! You wont have the cable like I do, it will be a bar attached to the I Hook!
http://i64.photobucket.com/albums/h1...handles016.jpg
If your door wont open hit it from the outside or inside to free up the latch Or drive around on bumpy roads <<<it works trust me!
After you get it open spray lube in the latch, if that doesn't work then remove the door panel push it up just a little & it should work....then lube the hell out it!
YelloEye Feb 20, 2009 07:14 PM
I've experienced this problem with both my doors, usually i just "jiggle" the handle open and closed quickly from the outside to fix it then spray lube in there.
Thorin Feb 21, 2009 04:33 PM
i just hit it from outside as you said and the door now open!!! thx
BlilBT Feb 21, 2009 04:37 PM
No problem & spray that latch with some lube, if you are in wet conditions use silicone spray lube it last longer! 1st time I seen this was on a buddies car about 2 years ago!:cssNET:
