problems after dual pass install
Old Dec 24, 2014 | 07:40 PM
talkeddelta8's Avatar
so i installed a dual pass and option b tonight. no i have all sorts of issues going on. it idles fine, but when you start to drive it it goes into limp mode and thorws these codes,
P0069 Supercharger Inlet Pressure (SCIP) - Barometric (BARO) Pressure Correlation -PCM
P0121 Throttle Position (TP) Sensor 1 Performance -PCM
P1101 Intake Air Flow System Performance -PCM
P1182 Supercharger Inlet Pressure Sensor Performance -PCM
P2229 Barometric Pressure (BARO) Sensor Circuit High Voltage -PCM
cant find any pinched wires or problems. could have a vacuum leak or any ideas,
please help thank you
Old Dec 24, 2014 | 07:50 PM
also forgot to mention when driving the idle goes up to like 3k rpms and holds.
Old Dec 24, 2014 | 08:14 PM
Sl0wbaltSS's Avatar
problem with the throttle body.
Old Dec 24, 2014 | 09:04 PM
Like what are you thinking. Is there a re learn or anything
Old Dec 25, 2014 | 01:58 AM
Jesse's Avatar
First things first, check all the connections to make sure something didn't get unplugged or wasn't forgotten.
Old Dec 25, 2014 | 10:53 AM
I did I triple checked everything all plugged in
Old Dec 25, 2014 | 01:10 PM
TStone's Avatar
I bet the scip and baro sensor plugs are backwards. swap those plugs
Baro sensor should have an orange wire with a black stripe, gray wire with a black stripe, and white wire with a black stripe.
Scip should have orange wth a black stripe, light green, and a gray wire.
Old Dec 25, 2014 | 03:27 PM
chris88z24's Avatar
Make sure you didn't bend any pins in the throttle body connector.
Old Dec 25, 2014 | 05:59 PM
Dude your a life savor thats what happened. Thank you so much. Car runs great now
Old Dec 25, 2014 | 06:02 PM
TStone's Avatar
Merry Christmas! You're welcome.
Old Dec 25, 2014 | 06:33 PM
Merry Christmas to you as well
Old Dec 25, 2014 | 10:28 PM
goaliemo's Avatar
I did the same thing. It sounded like the car was going to blow up when I went to move it. I don't feel as bad admitting it now. LMAO
Old Dec 27, 2014 | 11:29 PM
Alwayswhining06's Avatar
I did it too... I'm going to investigate in the morning. I hope I just mixed up the Scip and Baro sensor plugs.
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
