problems after dual pass install
so i installed a dual pass and option b tonight. no i have all sorts of issues going on. it idles fine, but when you start to drive it it goes into limp mode and thorws these codes,
P0069 Supercharger Inlet Pressure (SCIP) - Barometric (BARO) Pressure Correlation -PCM
P0121 Throttle Position (TP) Sensor 1 Performance -PCM
P1101 Intake Air Flow System Performance -PCM
P1182 Supercharger Inlet Pressure Sensor Performance -PCM
P2229 Barometric Pressure (BARO) Sensor Circuit High Voltage -PCM
cant find any pinched wires or problems. could have a vacuum leak or any ideas,
please help thank you
I bet the scip and baro sensor plugs are backwards. swap those plugs
Baro sensor should have an orange wire with a black stripe, gray wire with a black stripe, and white wire with a black stripe.
Scip should have orange wth a black stripe, light green, and a gray wire.
Dude your a life savor thats what happened. Thank you so much. Car runs great now
z28addiction
Sep 28, 2015 12:03 AM
