Reverse lights don't work.
Old Dec 23, 2014 | 02:33 PM
yellow dragon's Avatar
So my reverse lights don't work. Bulbs are fine and fuse is fine what could it be?
TStone's Avatar
reverse switch
Old Dec 23, 2014 | 02:37 PM
TStone's Avatar
How do you know bulbs are fine?
Old Dec 23, 2014 | 02:38 PM
TStone's Avatar
reverse switch is on the trans
Old Dec 23, 2014 | 02:39 PM
Sl0wbaltSS's Avatar
have you tried turning it off and back on?
disconnecting the battery and reconnecting it.
Old Dec 23, 2014 | 02:40 PM
Brand new and I can see the filiments are fine.
Old Dec 23, 2014 | 02:41 PM
TStone's Avatar
Well if the fuse is fine, then it's probably going to be the reverse switch. You can check for power at the fuse, then check for power at the reverse switch(pink wire), and then check for power at the bulb(light green wire).
Old Dec 23, 2014 | 02:42 PM
Yup tried all that. I will look at getting a switch they ae cheap enough to get.
Thanks
Old Dec 23, 2014 | 02:43 PM
TStone's Avatar
To be sure, you can try to jump the wires at the switch and see if they'll work.
or see if there is power going to the switch, put it in reverse, and see if there is any power coming out of the switch
Old Dec 23, 2014 | 05:57 PM
chris88z24's Avatar
Reverse sensor on top of trans. NAPA carries the replacement. Easy fix.
Old Dec 24, 2014 | 07:15 AM
Thanks
Old Dec 24, 2014 | 08:57 AM
blueLNFftw's Avatar
You need an oxygen sensor socket to get it out and in though.
Also, do not torque the **** out of it.
Old Dec 24, 2014 | 09:09 AM
TStone's Avatar
oxygen sensor = 7/8 wrench or a 22mm wrench or a many sixteenths wrench aka adjustable wrench
Old Dec 24, 2014 | 09:10 AM
blueLNFftw's Avatar
It has to be an extra deep one though. If you use a socket you do not have to take anything else out. Long extension and the magnet in it holds the switch in place. Makes it a 30 second job.
Old Dec 28, 2014 | 10:16 PM
Thanks
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
dieGone
Oct 1, 2015 06:27 PM
Stuff
Oct 1, 2015 05:47 PM
