Second Gear going bad?
While the car is off I can shift through all the gears fine. Once I turn it on only the second gear has a problem going in. When going in from first to second if I try to put it in right away it kinda grinds but if I wait like 2 seconds then it goes in fine. The rest of the gears are fine its just second that does this.
Should I be looking into getting a new trans? Also just to add I read a cel on my car P0833 Clutch pedal switch 2 circuit malfunction |
Originally Posted by Wind
(Post 7675654)
Could be a syncro, but I wonder if your cables are out of adjustment?
(Post 7675670)
Originally Posted by Kolt
(Post 7675655)
sounds like the syncro is going out. not the gear itself.
Does anyone rebuild transmissions |
I changed my shifter out and couldn't get it in 2nd off or on. Adjusted my cable and it worked fine.
2 Attachment(s)
If it's grinding though, it's either the clutch isn't fully disengaged or the synchro is going out... and since OP is only having the problem with one gear, it's most likely the synchro.
This is likely to be your problem. See how the three inner "wings" on this ring look a little flattened/grooved? Attachment 62709 That prevents it from dropping down into the corresponding grooves... as seen here. Attachment 62710 In this case, it was from downshifting very hard from 3rd to 2nd. |
So what do you guys think that I should do?
Check and adjust your shift cables first, then prepare for a trans if it continues or learn to rev match your shift. From what I hear its cheaper to get a new one than rebuild.
You can have them rebuilt, but the really good guys who do them can sometimes have a long turnaround time.
(Post 7675735)
- - - Learn to double clutch. Drive it until you can find a replacement. |
(Post 7675837)
More than simple rev matching, he'll have to learn to double clutch. It's not impossible though.
Eh, it's not that bad once you get the hang of it. I did it for a little while with my OE transmission back in 2006.
I had the same thing happen about a year ago, one day trans was fine, next day was a little hard to get in first, then did just like yours, I figured something broke in second, probably the syncro and I thought about fixing it myself but wasn't sure where to get parts or if special tools were needed to split the case, I ended up finding a used trans (kind of hard to do) and put the old one on the shelf should I have problems again and then fix it.
Originally Posted by Sharkey
(Post 7675847)
if i had to double clutch 2nd gear to get it to go in, and i had to drive the car i think id simply shift 1st to 3rd.
I guess I'm just going to have to find something used lnf, lsj and redline all have compatible trans right? |
Originally Posted by sixgear
(Post 7675857)
(Post 7675863)
This is what I've been doing tbh lol
Im so popular today
So easy, even a grandma can do it!
Did a search and came across this thread. My second gear grinds going in but if I double clutch, it goes in fine. I'm certain it's a synchro issue, but does anyone know of a good transmission guy?
