spark plugs question... again
I got some answers but i want to know what other people think or give some feedback.
So let start with timeline.
car is a 2.4 boosted at 10psi, with 39# injectors, with spark plugs gap at .034, car is catless.
the car would misfire a lot at cold idle and a little when warm. Car had a really, but really light smell of gas through the exhaust. Spark plugs were the autolite use in zzp turbo kit, but i had this problem also in ngk too.
Now, I changed the spark plugs to ngk again but gap to .030. The misfire at cold idle is much less than before. The gas odor from the exhaust tho got stronger, much stronger.
Now my questions are;
1. Is the gap too small? (from research I found that it could be the issue, but the misfire at idle is much less)
2. Is the coil packs are going bad or getting weak?
That's all I can think of right now,
If you have any question or I didn't provided some information, please feel free to ask.
What is your AFR at idle? Because if you're smelling gas i'd guess its not where it should be, that would explain the misfires. Honestly it seems like the tune isnt correct. You could always make sure the connectors on the coil pack to the spark plug are free of corrosion first, but I'm betting its the tune if this has been the issue ever since you boosted it and put the 39# injectors in
car still have the 39# injectors,
AFR is back and forth because there is no sensor in the car due to catless.
misfire feels like a vacuum leak but cant find it, i did the vacuum leak test and everything.
car accelerate and drives fine with no misfires.
Did this tune ever have the car run correctly?
The rear o2 not being installed has nothing to do with AFR. That sensor is for cat efficiency only.
Are there codes?
P0300?
Are there codes?
P0300?
Last edited by blueLNFftw; Jan 31, 2015 at 09:43 PM. Reason: Automerged Doublepost
Good question, I think so lol
They are the one that came in with the first gen zzp turbo kit for 2.4 air liquid cooled.
I have a set of 60# used from zzp too stored.
That's up to your tuner. I don't know anything about the 39's or the tables for them. Only know the 60's are tried and true.
What is your idle afr fluctuating? Is it idle hunting?
At idle afr should go between 14.3 and 15.1, if it's going from 12-16 that is not correct. If your catless a slight fuel smell in the exhaust is normal though, I wouldn't worry about that. What ngk plugs did you try? .032 is certainly not too small of a gap, I ran .026 for a while just fun. Do you have HPT? would be helpful to see what spark is doing
the smell of gas was there but wasnt that strong, now it got stronger.
yes HPT
iridium LTR6IX-11 gapped at .030
you can take a look at the old chart too both in my album
here is the dyno chart, end of the graph is the blowout, with autolite gapped at .034
not too long ago
4th gear pull and one 3rd gear pull
yes HPT
not too long ago
Yeah your fluctuating to much on your AFR for sure so have that checked out. And my numbers where just a type of reference not exact numbers just to give you and example on what it should do but the closer to the 14.7 the better
yes HPT
not too long ago
yes HPT
not too long ago
Video of AFR at idle
You can see the misfire, that misfire after the kit was changed from air/liquid to air/air system.
The only thing that was changed was the position of the maf and had to be extended.
You need to get a tune update, your VE and MAF tables are not agreeing or your injector tables are off and the narrow band is trying to compensate, you should idle at 14.7 and only change to 14.5 to 14.9 at most.
The only thing that was changed was the position of the mad and had to be extended.
AFR at idle - YouTube
It is and it isnt, like the supercharger intercooler system, it relies on the size of the cores in the air-water exchanger to be efficient, but yes water has a higher thermal capacity then air so it can remove much more heat then an air to air system, IF the intercooler core is large enough.
