Need serious help
Need serious help
Im brand new these cars, 05 SS/SC btw, (like less than 2 weeks) and already having an issue. One night, I lost my gauge lights (not the dash, just the lights behind the speedo and tach) and my radiator fans will not turn on. Ive asked around and everyone points to the PCM (also have a slight misfire at idle and gauges read weird sometimes). Decided to pull it out and see if maybe cleaning the contacts would help annnndddd the car wont start. Security light is on, everything works, but doesnt start. Need to do a key relearn or is it possible I completely fried the PCM?
If your security light is on and nothing else came on you could need to do a security relearn. There's also a possibility you bent some pins or something and the ECM isn't getting proper connection.
As far as your fan goes will it not kick on when the AC is running?
The misfire is probably a separate issue.
I don't think loss of gauge lights would be ECM either. I would just think they either went bad or lost power for some reason.
