Steering rack or intermediate shaft problem?
So, I've hunted around and read a bunch of posts, and I think ive found what the other phantom noise is on my car.
Car has pulled to the left randomly for awhile now, and whenever you turn you hear a clunking noise. Steering response also just doesn't seem right. Its not horrible, its just.. varied i guess would be the best way to describe it. Reading others posts it sounds like it might be the intermediate shaft going bad, but im wondering, since I have 172,000 miles on the car, if i swap that out, should i replace the steering rack as well? Or has anyone else had these issues and found it to be something else? |
Same problem here, in for updates.
Intermediate shaft! Mine does the same thing. I work at a service station and we get cobalts all the time that have a "clunking when turning" we replace the rack and they're back in a week because the noise is still there
Good deal. Everything is leaning towards the shaft, didnt wanna replace the rack unless i had to. Time to call the shop, haha.
The shaft is pretty easy to do yourself too.
Yeah.. I see it on rock auto... getting a quote from my buddy tho, since he has a lift and more free time than I do, heh.
Turns out the rack came loose. Again. -__- taking a good look at it on the list thursday. the 2 bolts keep backing out
Hmm... Maybe I should check mine.
Originally Posted by Foximus
(Post 7351998)
bolts are tight. rack is moving side to side..... going up on the lift in the AM,.
I think I may have the same issue. When you take the steering wheel and go back and forth kind of rapidly i hear a clunking noise. Could that be the same issue as everyone else is discussing?
Yea. Standing still, or at low speeds you would turn the wheel and hear a clunking noise. I also noticed my steering didnt always come back center. The nut in the subframe wasnt keeping torque (The bolts have been tightened 4 times since March) So we ran a larger bolt thru the rack, and the subframe and put a washer and locknut under the subframe to see if that solves it.
(Post 7353832)
Yes. I dont have the spec's off hand. but i would make sure your rack is torqued down properly first before going on to look at other things.
(Post 7355437)
