Transmission parts not available?
I have a 2006 Cobalt SS/SC and I am having a shop install a Quaife LSD, a 4.45 final drive gear, flywheel, clutch etc. They noticed that my pinion bearing and differential bearings need to be replaced, but they can't find anyone who sells them. They said that parts were not available since it is a Saab transmission. I also need a new 5th gear hub and slider (I'm quoting the shop since I don't know what those are). Does anyone know where I can find all of these parts?
Thanks in advance Eric Hill |
Tap tap. Is this thing working? :)
shuld have just went to JP
This is the 5th gear hub part number: 09117779
Im not sure if that comes with the sliding ring but for the price, id hope it does. Side bearings for differential: 90490865 Im not exactly sure which bearing is the pinion bearing but if you could point me in the right direction i can probably find the part number for that as well.
(Post 7305195)
Thanks so much! I assume these are GM part numbers? What are the prices?
I just called my shop (Kaizenspeed) and they said that they ended up contacting Powell Race shop (on my recommendation) to get the parts. So, if you need parts for your transmission, go to John Powell. Thanks John!
