Water on floor problem solved.
Hello all,
Just wanted to thank the OP about the water on the floor problem for saving me time and money...a mechanic told me it was probably a leak from the hood release gasket as someone else had mentioned and they could explore the issue for 75 bucks a hr. I came back to the forum here to see if anyone else had any other ideas on what it could be when I ran into the sunroof drain issue soemone had...so I checked it out and sure enough after removing the A pillar and pulling the top down a little and pouring a glass of water down the drain (in my face ) I found the hose had come off the drain and was pouring down the A pillar ,and onto the carpet....saved me some bucks and I apprciate it. If anyone needs any more info if they are having the same problem PM me and i'll explain in more detail. THANKS GUYS YOU ROCK! Now back to soaking up water with the shamwow! PS Our GM dealer must have dislodged it when they chaged the sunroof switch so if anyone else has had that done be careful.
