Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   Problems/Service/Maintenance (https://www.cobaltss.net/forums/problems-service-maintenance-69/)
-   -   Weird CEL??? (https://www.cobaltss.net/forums/problems-service-maintenance-69/weird-cel-79905/)
CobaltVenomSS Oct 11, 2007 12:15 AM
Weird CEL???
for the past 2 tanks of gas ive had i got a CEL at almost exactly half tank and then it goes away around 1/8th tank it has done this on the past 2 tanks of gas....im going to be around half tank tomorrow so well see what happens...
Note: i always use 93 (chevron )
Coblasts Oct 11, 2007 12:24 AM
Whats Cel are you getting.
Try and get the code to better help you figure out whats causing it.
CobaltVenomSS Oct 11, 2007 12:26 AM
yea if it comes on again tomorrow i was gonna head to autozone before work
XM15 Oct 11, 2007 12:27 AM
Even if the light isn't on, since it has come on several times the code will probably be there. Get it checked anyways.
CobaltVenomSS Oct 11, 2007 12:29 AM
anybody know what it might be?
Smitty1017 Oct 11, 2007 03:30 AM
maybe its that one you get from not closing the gas cap tight enough?
CobaltVenomSS Oct 11, 2007 01:05 PM
yea tighten as much as possible
The light came on today :(
njg5gt Oct 11, 2007 01:09 PM
it's your old car coming back to haunt you for getting another one....
idk man try getting the code and letting us know
CobaltVenomSS Oct 11, 2007 01:11 PM
lol it told me 2 move on
:bye: :bye: ITS SAYING GOODBYE :bye: :bye:
http://a26.ac-images.myspacecdn.com/...0abc3eef11.jpg
fr33k Oct 11, 2007 01:56 PM
There's 4 different DTC's on the fuel level sensor.
P0461 Fuel Level Sensor Performance
P0462 Fuel Level Sensor Circuit Low Voltage
P0463 Fuel Level Sensor Circuit High Voltage
P0464 Fuel Level Sensor Circuit Intermittent
CobaltVenomSS Oct 11, 2007 02:10 PM
well i always put 93 in it..should i try a different gas station?
Novajoe Oct 11, 2007 03:16 PM
you should try getting us the code so we can tell you what the problem might be...
CobaltVenomSS Oct 13, 2007 01:41 PM
i finally got it checked out...they said its a cylinder misfire
silentd Oct 13, 2007 01:42 PM
time for new gas or plugs... are you running a step colder?
bykryder83 Oct 14, 2007 04:20 AM
i have the same code po300 random multiple cylinder misfire wtf is that i have a 2.2 btw it would come on sometimes but tonight i put the cams in and its all the time i think its a bad o2 or something
Novajoe Oct 14, 2007 10:54 AM
can you give us the specific code? Is it a random misfire or a single cylender misfire?
On these car's it's impossible for a bad O2 to cause a random misfire. If there's an O2 code then it won't allow the P0300 to set.
You just replaced your camshafts... I'm guessing you mean aftermarket cams right? You more than likely need to make timing adjustments for them.
rallyracer Oct 14, 2007 11:00 AM
This started to happen to my old Cavalier...I never did figure out what the hell it was.
bykryder83 Oct 14, 2007 06:58 PM
i had the code b4 the cam install
