Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   Problems/Service/Maintenance (https://www.cobaltss.net/forums/problems-service-maintenance-69/)
-   -   what the hell is this horrible noise? (https://www.cobaltss.net/forums/problems-service-maintenance-69/what-hell-horrible-noise-331368/)
xtcydom Dec 25, 2024 03:31 AM
1 Attachment(s)
noticed the car has made this bone chilling screeching noise since I bought it, only happens when first turning the key over into acc mode before even starting the engine, sounds like some sort of electric motor going bad but im happy to replace it as soon as possible
stevieturbo Dec 26, 2024 06:18 AM
you need to have someone else cycle the key while you're looking and listening.
2006lsjcobalt Apr 9, 2025 06:48 PM
did you ever find out what it was? Mines making this now just not as loud
branden.garrod.19786 Mar 27, 2026 10:02 AM
Recirculation door actuator motor
This clicking noise is an actuator motor for a blend door on the HVAC system. If it is in the upper passenger side of the dash it is the recirculation door if it is down in the middle of the dash by the throttle pedal then it is either the blend door (temperature) or the Mode door. There are three actuators, blend, mode, and recirculation. The clicking is the gears trying to open the door and slipping.. this is obvious bevause it happens when you turn the key to the on position and it tries to reset.
