R1 Concepts| PREMIER SERIES ROTORS & BRAKE PADS (*NEW PRICING!*)
R1 Concepts is proud to offer Premier Series Rotors!
R1 Premier rotors provide the ultimate stopping power needed for demanding driving and harsh conditions. Manufactured using more Carbon, Chromium, and Molybdenum, these high carbon rotors offer increased braking performance and strength. A center split core casting design provides greater stability. Black Electro Coating protects against rust while extending rotor life. Mill balancing and double disc grinding reduces thickness variations for smoother stopping, minimal vibration, and improved break-in. All R1 Premier rotors are designed for direct fitment; no modifications are required. What separates R1? Here at R1, we take into account numerous precautions in machining rotors. We drill our rotors in house using state-of-the-art CNC machines and follow strict procedures and standards such as drilling between each vane structure. This will allow the rotor to retain its structural integrity and overall strength with optimum thermal transfers. We utilize smaller diameter drill bits for smaller diameter holes and each hole is counter-sink to add strength. You also have the option to go with slotted only or even a custom design with your own logo. Every R1 rotor that comes with slots will come with our Diamond Slot design (45 degree angle end points), to help release trapped debris. Our diamond slot design is also a good indicator for rotor wear. Warranty Here at R1 Concepts, we stand by our products. We offer a one year warranty on warping and cracking on all R1 brake rotors due to manufacture defects and workmanship. http://www.r1concepts.com/images/forums/y-rotors-ds.gif http://www.r1concepts.com/images/forums/y-pads.jpg http://www.r1concepts.com/images/forums/y-g2paint.jpg Drilling Patterns Dimpled & Slotted Drilled & Slotted Dimpled Slotted Drilled FT/RR PREMIER SERIES ROTORS 05'-08' COBALT SS 2.4L SINGLE PISTON FRONT CALIPER & SS 2.0L SUPERCHARGED BREMBOS : $290 SHIPPED 08'-10' COBALT SS BREMBO FRONT CALIPERS W/ VENTED REAR DISC: $300 SHIPPED BRAKE PADS FT/RR POSI QUIET CERAMIC BRAKE PADS (05'-07' SS 2.4L SINGLE PISTON): $80 SHIPPED FT/RR POSI QUIET SEMI-METALLIC PADS (BREMBO FRONT CALIPERS): $90 SHIPPED FT/RR HAWK HPS BRAKE PADS (05'-07' SS 2.4l SINGLE PISTON): $115 SHIPPED FT/RR HAWK HPS BRAKE PADS (BREMBO FRONT CALIPERS): $180 SHIPPED BRAKE FLUID STOPTECH STR-600 (500mL): $16 STOPTECH STR-660 (500mL): $24 CONTACT Kevin C. Kevin@r1concepts.com 888.712.6623 ext .7022 |
Weekend bump
Weekend bump
Ran these when i owned my TVS cobalt. many times breaking past 140mph ( in mexico of course ) never had issues. painted hats and rotor edges were huge in keeping the rusty look out. service was excellent
Weekend bump
What's the difference between these rotors and the ones I bought from your last year? And what's the price for just a front set for the lnf?
Originally Posted by SR Tech
(Post 7615710)
Weekend bump
