Best swirl remover?
wat is the best swirl remover u guys have used? i need to get some and i dont know wat brand is best since this would b my first time using swirl remover
I prefer to use Meguire's swirl remover 2.0
this takes all the swirls off my hood from cleaning it correct?
I would like to know this also, and do I need a porter cable?
depending on how deep the scratches are, you might need some type of wax foundation to remove them... i woujld also invest in a buffer
I would go right to the Porter Cable with a light compound. I use Zaino PC.
The Swirl Remover is just part of the equation, proper technique, correct pads/speed will = Great results:)
TEC 565 by Technician's Choice. It's a pink color. This stuff works amazing!
Depends what you have access to. If you have a Porter cable, I would go with Swirl X. If by hand I would go with maybe Scratch X 2.0. Both topped with a good wax. (my suggestions, NXT 2.0)
