engine bay dirty... need help
https://cimg7.ibsrv.net/gimg/www.cob...1972717100.jpg
https://cimg9.ibsrv.net/gimg/www.cob...7f4ed35d3b.jpg what can I do for cleaning that? |
What you are seeing is not really cleanable. Its basically... Oxidation? The solution that most people take to amend that is to remove parts and paint them lol.
However before going that route it does help a little to get a wire brush and some brake/engine cleaner and get with it |
I like simple green, and simple green max automotive degreaser Both work amazing, they are also both great for cleaning dirty tires and fender wells. Also works great on stubborn brake dust, but brake dusts a bitch. |
I'd use simple green before brake cleaner....
ok i will try with simple green
I'm going to give this a try my bay is terrible
Pretty sure you can dilute simple green. Still works well and lasts longer.
Simple Green is a good engine bay cleaner though remember that it can speed up the corrosion process on aluminums.
Originally Posted by mjcarls
(Post 7604470)
I have the same issue on my ss/tc. ive been curious if vinegar will work similar to how it works
on steel. haven't tried it yet though. |
Originally Posted by Kolt
(Post 7604515)
I've always used a 50/50 mix of simple green.
My bay looks like the day I drove her home new 9 years ago. |
im coming to JP's Auto Detailing for a complete detail ... exterior and engine bay ... i wont be satisfied until my car looks better than yours :lol::lol::lol: lmao
(Post 7604564)
Over the summer I had an experience with this and I found a way to brighten the blower up, but it stained some of the plastic like the engine cover and etched spots into the clear coat on the coil cover.
What I did was cover the engine and used mag wheel cleaner on the blower housing – I don't recommend it. Were I to do it all over again, I would just accept the blower corrosion, clean the bay, and call it done. I'm still hunting for a good engine cover to replace my stained original. Here are some links to the posts I wrote about it: Cleaning the Cobalt's Go Parts Engine Cleaning Oopsie Day 6: More Clay Barring for the Cobalt Down the Homestretch If you're interested, I documented the rest of ordeal as well. The blower did end up looking nice, but it wasn't worth the damage or potential damage to everything else under the hood. |
The absolute best way I’ve found to clean my blower is simply goin at it with a steel wire brush. Got one from autozone for $3 and had that thing sparkling. As for the block, I haven’t really done the best with the brush, it doesn’t work the same, so the above mentioned products are probably better to use.
