Show & Shine Detailing, washing, waxing, paint care, wax, etc.
good buffer?
Old 04-29-2011, 01:53 AM
heathkidder's Avatar
good buffer?
so i have always used a crappy buffer or mostly hand buffing which gets old i want a decent buffer but dont want to spend alot of money on one at the same time.
what is a good but cheaper one to get also i know hardly nothing about one. i know the different in the pads but how exactly are they used?
just simply apply the pad on the buffer and apply the paste of your choice ?
im sure the buffer i get will have some sort of directions but looking to see whats good.
i know the porter cable is one of the highly recommended but alil to much for me right now.
Old 04-29-2011, 02:09 AM
bump sum1 give me some helpful info
Old 04-29-2011, 02:39 AM
nuthin?
Old 04-29-2011, 02:58 AM
Billy Baldone's Avatar
Porter Cable I use mine all the time. Go to Autogeek.net and look at some of their detailing tip videos they are very helpful.What are you doing with it?
Old 04-29-2011, 03:00 AM
I just read the PC is too much for you right now,That brings me back to what are your needs for a buffer right now?
as i said porter cable is bit expensive. and im doing what any other person would do with it lol but i am just asking about other types of buffers what to get and what to stay away from
Old 04-29-2011, 03:02 AM
porter cable would be nice. but at the same time i want something less expensive to work with for awhile. just the normal swirl remover,pre wax, sealant, wax
but with the different pads do you just put them on and apply the paste to the pad is all .... iv seen crappier types of buffers use cloth to put over there pads?
Old 04-29-2011, 03:06 AM
To have the ability to remove scratches and apply polishes, the price range of the PC is at the low end of the buffer/polisher market.There isn't anything in the 50-100 range that gets th job done,You can buy a PC for 125 if you shop around.Don't waste yur money on anything less,And a non dual action polisher will burn your paint easily.I'm sorry it isn't the answer yo wanted but the cheapie WAl Mart type polishers you see fr 35 bucks won't cut it.
Old 04-29-2011, 03:10 AM
yes i have used one of those and it was pointless but i was wondering if there was anything good between those and the pc is all. i may end up getting one of those but in all honesty is the pc worth it. how does it compare to being applied by hand?
and like i asked before with the pads. is it as simple as putting the pad on and the paste and your set...there is no cloth on the pad like the crappy ones right?
You need the ability to apply swirl removers/polishes at about 4000 to 5500 RPM.The new Meguires paint correction kit requires 4800 rpms.For the most part yes you apply which ever product you need to the pad and work it in.Terry cloth covers that go over the bonnet of the cheapies swirl your paint.
Old 04-29-2011, 03:13 AM
Yes The Porter Cable (PC) is the well worth it. It is the most used tool in my garage when detaailin a car.You won't get swirls out by hand.I use mine to apply wax with red pads at a lower rpm and swirl remover with orange pads at about 5-5500 rpms.Doing it by hand won't do it.
Old 04-29-2011, 03:14 AM
ok but on the pc those type of pads dont require a cloth cover correct? im sure once i look hard enough ill find it on that site but its nice to get first hand info on things. im a buffer noob but i did no the pc was one of the better ones out there.
whats the best steps of applying paste?
i usually wash it/clay bar atleast 2 or 3 times a year/wash again/dry/compounding sometimes but not much for me./swirl remover/prewax/sealant/wax
Old 04-29-2011, 03:16 AM
with a white car i get most of whats there but i still see it also.
whats the most common rpms to use when applying any type of paste?
also i notice the most common pads to use are the orange/white/red
Old 04-29-2011, 03:24 AM
Yep you only need the pads no covers.To keep the swirlies away starts with the wash.here's what I do,I know others have their own process.But this is what I do on my black Miata
Wash car using Wolfgang car shampoo and my DO DO Juice Wookie fist wash mitt.
Dry car using Waaffle weave drying towels.
I don't clay bar unless I feel the debris build up on my paint.If you have a good wax on it you won't need to claybar much at all.
I then see if there are any swirls I need to correct,if so I use an orange pad with Pinnacle swirl remover.After that,I apply Menzerna Nano polish with a white pad.I remove all poishes/waxes with Cobra microfiber,yes quality microfiber makes a difference.Then I apply Wolfgang Paint sealant(it's kind of a wax).After that I apply Autoglym wax by hand and finish off with Griot's garage Speed shine quick detailer.After that is all done you only need to wash your car and use the quick detailer for months before doing the long process over again.
Old 04-29-2011, 03:28 AM
4500-5500 rpm for swirl remover
4000-4500 rpm for wax'polish
orange light cutting-swirl remover
white very very light cutting-polish
red no cutting-wax
yellow heavy cut-deep scratch remover
Old 04-29-2011, 03:30 AM
so i should only do this about once a month?
i do about the same steps you do but with differnt products minus the buffer lol
did you get my pm i have a few ?s
red no cutting-wax
yeah i know all about the pads just didnt no what rpms are the safest. it wont hurt the paint right
Old 04-29-2011, 03:31 AM
no once every 3-6 months depending on quality of producte you use.This **** adds up and gets stupid expensive.just wash and quick detail whenever you wash your car like normal.Checking PM's now I have to leave for work soon.The point of the PC is that it won't hurt your paint
Old 04-29-2011, 03:34 AM
yes iv realized the better known products the more exp. it gets its crazy i have a million diff. kinds to try and find one im settled with. i have just never used a buffer only a few times cause i never really trust them and doin it by hand causes me not to get it good enough and takes way longer
also i found the pc at sears for like 115 id like to get a carrying bag for it and the supplies but its like 50 bucks lol
Old 04-29-2011, 04:03 AM
Berto09ss's Avatar
oh im sticking around i need advice on how to really detail my car
Old 04-29-2011, 04:09 AM
im def. considering the pc now that iv seen alot of vids on it.
Old 04-29-2011, 02:09 PM
Old 04-29-2011, 06:58 PM
Are you bumping this because you think someone magically invented what you are looking for, for 50 dollars?You need to spring the money for a PC,there isn't anything cheaper that works as well,and is idiot proof.
Old 04-30-2011, 09:19 PM
Turbo Wax's Avatar
Here's the best price for them, if you are paying more than that they are ripping you off
Porter-Cable 7424XP Car Buffer / 7424 XP Polisher | Tools Plus
Old 05-01-2011, 12:59 AM
thanks pmd u again
Old 05-01-2011, 08:58 AM
pm replied. good luck grasshopper.Is that your car in your sig? think it looks pretty nice.I love white cars.
Quick Reply: good buffer?
