new to washing car so
yes i know their are a million threads but i dont wanna get as in-depth as they get on cleaning their cars. I bought meguires deep crystal car wash and their clay bar kit and this is what im planing on doing....if u got something to add please do
1. thinking about mixing car wash soap with dish washing detergent to remove old wax right?
2.dry obviously
3. clay bar and wax and all the **** that comes with the kit
mainly i just wanna know what else i should do and if i should change #1
2.dry obviously
yea easy enough you should just use soap and water when you clay it instead of the detailing spray they give you.. thats what i do and i feel its alot quicker and easier
A pretty simply way to keep you car nice is this.
Simply wash, use dishsoap if you're going to wax/claybar. No need to mix it with normal car wash soap.
Dry, obv.
Use the claybar kit.
Wax.
You only need to claybar once every 6 months or so. This is a great time to do it, since winter is now over and the claybar will get the car super clean.
Waxing should be done more often, depending on how fast the wax you use goes away. You can tell that by how the water beads up. Good rule of thumb is every 6-8 weeks or so.
Dry, obv.
Wax.
No need to... you're going to be using the clay bar, so you want it pretty bare and clean, which is what the dish soap will do.
As long as you're only using the dish soap as getting ready to wax, it's fine. For normal just washing, use car soap only.
Just be sure to keep the area where you are using the clay bar wet with the detailer spray that should have came in the kit. That's the only area where you can mess your car up, is by using the clay on the car when it's dry.
Also use a good wax... In general anything in a can is awesome, and will be worth the effort it requires.
I was really hoping some newb would come out and say that they shouldnt mix 2 different soaps because it has a massively explosive or corrosive PH balance a to clear coat.
Yea what they all said basicly, just make sure your car is soaped really well before you clay.
btw:
Anything in a can is worth it? lol?
btw:
WHOA!!!!!!!!!! NEVER...and I repeat....NEVER use dish soap on your car. That soap is not made for a car and should not be used........period!!
Other then that though, wash the car, clay, wash again, dry, and wax.
As for wax.........GO HERE : http://www.zymol.com/index.aspx
The wax is expensive, but it is some of the BEST on the market and worth every penny in my opinion. I use nothing but Zymol on my car from the soap, to the wax, to detailing the interior. This stuff is the best.
