Show & Shine Detailing, washing, waxing, paint care, wax, etc.
Removing emblem residue
Old Oct 6, 2010 | 06:37 PM
06.ss.sedan's Avatar
Post Removing emblem residue
When I bought my car it came with the dealership badge on it and of course without thinking much I just pulled it off. Now Im left with a couple inch long white foam stuff that was left behind. So if anyone knows a easy, safe, and painless way of getting it off, please let me know!! Thanks
Old Oct 6, 2010 | 06:40 PM
redcobalt07's Avatar
goo gone
Lapila82's Avatar
goo gone
Agh. Beat me to it!
You should wax it too when you're done, just because it's freshly exposed.
Old Oct 6, 2010 | 06:42 PM
troyss's Avatar
Take an hair dryer to it first and push away with finger when it's hot then use goo gone for or opps to get the little stuff off
Old Oct 6, 2010 | 07:36 PM
Thanks guys
Old Oct 25, 2011 | 10:41 PM
metzO7's Avatar
mineral spirits on a rag dab a little on the rag rub on the foam and it will loosen the adhesive wipe off with clean towel repeat as necessary till gone have done this many times with out any damage to the paint just don't get carried away with it
Old Oct 25, 2011 | 10:57 PM
TommyP's Avatar
AWD > FWD
at work we use a pressure washer, then some goo gone to get the left over residue. I HATE those thick dealer badges, the vinyl ones are much better.
Old Oct 25, 2011 | 11:12 PM
Powell Race Parts's Avatar
Originally Posted by Lapila82
Agh. Beat me to it!
troof x 236804394875754
Old Jan 30, 2012 | 03:45 PM
CavalryTurbo's Avatar
Lighter fluid. No ****.
Old Jan 31, 2012 | 09:48 AM
dakotaspeir's Avatar
#cobalthoes
wd-40 and some rubbing with a micro fiber
Old Jan 31, 2012 | 10:05 AM
ChevelleGrl's Avatar
automotive safe goo gone.. will need to spend some time with it.. but it works..
Old Feb 21, 2012 | 08:03 AM
windsorSS's Avatar
Get a hair dryer, keep the heat on it, then take nylon fishing line and slowly slide it back and forth behind the foam (Easier if the badge is still attached), once you got it off. Use automotive safe goo gone (no citric acid base is what to look for). Then make sure to wax the crap out of it.
Old Feb 21, 2012 | 08:55 AM
THIS! exactly what i did to mine.. works great
Old Feb 21, 2012 | 09:23 AM
LS6Rally's Avatar
you can use gasoline if you already have some, no matter what you use you should wash the area afterwards and wax the area like said above.
Old Mar 17, 2012 | 06:49 PM
aerojt's Avatar
Goo Gone Gel I have found clings better and removes easier. Just my.02 though.
Omiotek's Avatar
dupont 3812 over everything.
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
footballplaya3k
Sep 30, 2015 09:39 PM
dieGone
Sep 23, 2015 10:20 AM
katahdin_lubricants
Sep 20, 2015 07:24 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
