water spots on my windows
got a little problem got a couple of water spots on my windows and i tried everything and still nothing !!!!!!!!! is there a way to get them off?:cssNET:
do you dry the windows right when you dry the rest of the car??
try running a razor over them
windex?
Originally Posted by roccobladr
(Post 1461621)
windex?
(Post 1461621)
windex?
try windex with newspaper also, newspaper gets windows cleaner than anything i've ever seen! |
Hrm interesting I would have thought the newspaper would get ink on the windows.
Originally Posted by CobaltPerformanceParts
(Post 1462575)
holy shit, i didnt know AEM had a mth kit, shiz i'm kinda loyal to them i love their products. one question, do they offer one of those adjustable controllers for inside the car? |
if it is a hard water spot you should CLR or a calcium and lime remover dulluted 1 to 1 with water it will come of with a little rubbing. it happend to my friends tsx type s the neighbor hood he lives in has automated sprinklers and they are putting chemicals in the sprinkler to help the grass stay green and it will make hard water spots but clr and 2 hours got the car looking good as new lol
Originally Posted by Master Chief
(Post 1462601)
yeah i tried windex already , but i havent tried clr yet . i have some in my home , so ill give it a try . thanx guys !!!!!!!!!!!!!!!!:cssNET:
vinager and newspaper... shouldnt use windex on your windows if they are tinted
tell us how that works out with clr. I had spots on my whole car. I suspect not drying it off a couple times after washing it did me in. I got it out of the paint with Meguires clay bar, polish and gold class wax. It still remains on my windows and vent shades. I even clay barred the windows. I used every window cleaner I could find. It is annoying as hell. I also have little tiny black pit marks in my rims from brake dust. And yes I have used brake dust rim cleaner and followed the instructions so I did not stain my rims. I wash this car all the time and am getting a little peeved I cant keep her tight.
I use a product called Invisible Glass from a company called Stoner.
My dad got it for me, so I'm not sure where he got it, but it works great. I use it on the inside and out.... spray on windows, wipe off... cleans off dirt, grime, bugs, water spots.. its also Tint Safe and streak free.. |
invisible glass is the best window treatment stuff out there...Stuff is way better than windex and it will get your streaks and water spots out
use a brillo pad or s.o.s pad they are great for that and bugs also thats what i use
(Post 1462575)
use stoners brand invisible glass it works on all types of windows it works great me and my friends use it never had any problems with it
Originally Posted by SmOKe JeNsOn
(Post 1487830)
newspaper is great for windows |
i know this is a chrysler TSB, but its worth a try
This bulletin is supplied as technical information only and is not an authorization for repair.SUBJECT: Circular/Ring Marks On Glass MODELS: 2005 - 2006 (CS) Pacifica 2005 - 2006 (DH/DR) Ram Truck 2005 - 2006 (HB) Durango 2005 - 2006 (JR) Sebring Sedan/Sebring Convertible/Stratus Sedan 2005 - 2006 (KJ) Liberty/Cherokee (International Markets) 2006 (LE) 300/Touring (International Markets) 2005 - 2006 (LX) 300/Charger/Magnum 2005 - 2006 (ND) Dakota 2005 (PL) Neon 2005 - 2006 (PT) Chrysler PT Cruiser/Chrysler PT Cruiser Convertible 2005 - 2006 (RG) Chrysler Voyager (International Markets) 2005 -2006 (RS) Town & Country/Caravan 2005 (ST) Sebring Coupe/Stratus Coupe 2005 - 2006 (TJ) Wrangler 2005 - 2006 (VA) Sprinter 2005 - 2006 (WH) Grand Cherokee (International Markets) 2005 - 2006 (WK) Grand Cherokee 2006 (XH) Commander (International Markets) 2006 (XK) Commander 2005 - 2006 (ZB) Viper/Viper Coupe 2005 - 2006 (ZH) Crossfire/Crossfire Convertible DISCUSSION: Circular patterns may appear on the glass which are visible mostly when the glass is moist or fogged up. The size varies from 2-6 inches and are typically described as “rings” or “circles” that won’t clean off with standard glass cleaners. NUMBER: 23-035-05 GROUP: Body DATE: July 26, 2005 To determine if this type of mark(s) is present use a clean, moist cloth lightly wet the surface of the glass component. Carefully observe if these circular marks develop as the water from the cloth dissipates. Repeat this process on both the inside and outside of the glass component (if applicable) to identify which surface of glass (inside or outside) has the condition. If the marks are present on the outside of glass, this condition will naturally lessen with sunlight exposure and time. Customer concerns are mostly associated with this condition being present on the inside surface. If the customer wants the marks removed, they can be removed using a non-abrasive cleanser or polish. Appropriate materials are Calcium Carbonate (Bon Ami®) or a glass polish containing Cerium Oxide. CAUTION: Do not use any materials containing quartz or silicate abrasives. Typical examples of abrasive cleansers include (Ajax®, Comet®, Soft-Scrub®, etc). Cleansers with abrasives will scratch the glass surface and cause irreparable damage. PARTS REQUIRED: Qty. Part No. Description AR NPN Calcium Carbonate (Bon Ami®) or a glass polish containing Cerium Oxide CLEANING PROCEDURE: 1. Moisten a clean cloth with water. 2. Wipe the glass surface leaving a very fine film of water on the glass. 3. Observe the location of the marks on the glass. 4. If the marks are on the inside of the glass surface, take precautions to cover any of the interior components the cleanser could come in contact with. 5. Rinse the cloth with clean water. 6. Apply cleanser to the moist cloth. 7. Rub the surface of the glass with the cleanser in a circular pattern being sure to cover the entire area that the mark involves. 8. Wash off any residual cleanser material with a moist cloth. 9. Dry the glass surface. 10. Check that the removal has been successful by rubbing a moistened, clean cloth back over the cleaned surface and inspect for suction cup marks. 11. Repeat as necessary to remove all of the mark(s) from the glass surface(s). POLICY: Information Only 23-035-05 -2- |
well damn, I suggest you don't listen to me :lol: I'll modify my post....thanks
anyone try this stuff?
http://www.autogeek.net/diamondite-glasswork-kit.html I cannot find any of the other mentioned glass cleaner |
Vinegar will remove water spots
Go to your near by parts house and there is a product made by Glass Science. It is called "glass scrub".
That will remove anything on glass. |
