What products do you use to polish your rims?
Any recommendations on what to use for polishing up the stock polished rims? Curious on what people use or recommend. Thanks in advance :twothumbs
Windex
Are they clear coated?
i use the Meguiars quick detailer for wheels or i just get a clean cloth and just rub'n down. turning the cloth often.
Do not use any metal polish on them, they are clearcoated, all you need to do is wash them like you would the rest of the car.
Originally Posted by Beck
(Post 1681845)
what would happen if i did use metal polish on them if they were clear coated (not stock rims)
(Post 1681927)
metal polish is an abrasive material, its designed to actualy remove metal like sandpaper would, but works more like extremly fine sandpaper. basicly imagine taking 2000+ grit sandpaper to your paint.
Sweet... thanks for the replies... :twothumbs
I used a metal polish on mine, that blue paste lookin stuff thats in a round container. Made them really shiny...just went and got the container its called blue magic metal polish. Took out some scratches aswell as leaving them really smooth and shiny!
Put a couple of good coats of wax on them. Then the brake dust will rince right off.
Originally Posted by Ron From Jersey
(Post 1688742)
Wheel Sealant These guys pretty much nailed it. Stay away from a metal polish. Usually just a quick detailer will work. If they're really bad, you can use clay on them. Also, a light polish like ssr1, poliseal, etc will work as well. |
ooo clay will work? mine are bad and i need to fix it. Ive never used anything special for them just the same stuff as the rest of the car
You can use clay on wheels. usually I'll try some clay on real bad brake dust, etc. when the usual cleaners arent working.
tried meguires wheel cleaner on the bad spot and 97% was removed so ill try one more time then go with clay bar... i had a few questions reguarding paint thou. I have a deep scratch and few light scratches along with some part of the car that needs to be repainted... al spots arent big so i was planning on fixing with a bottle of touch up paint. im a noob at paint so any advise?
also im looking at that wheel sealant along with some microfiber rags from you... any chance theres a liquid version of the sealant? |
I bought some wheel cleaner at Dollar Tree and it worked just as well as the more pricey brands.
Originally Posted by jsscooby
(Post 1714612)
Well i have a problem. i took off my polished wheels and went to clean them and i used metal polish. Well to say the least they now look like shit. really shiny from far away but up close you can see the lines from the polish. What should i do?
dont think u can do much... if the metal polish fucked the clear coat
i have seen that meguiars hot rims paste, havnt tried it yet... i use black magic wheel cleaner which does wonders for my konig unknowns..
Motorcycle Polish.
Works like a fucking CHARM...I use it to clean the bike and it takes rubber off the undertail and grease off the rims so I tried it on my car. I'm sold for life... |
(Post 1818311)
Uhm Use A Copper/bras Cleaner:twothumbs
We Use It At A Returant I Work In I Stole It;) And Used It On My Exhaust Tip And On My Buddy's ///m3 Rims:cool::twothumbs It Works Great:#one::thumb: |
Originally Posted by Rev6 Maro
(Post 1688736)
