GM STAGE 2 OR Rebals stage 1
I am looking for for a stage kit but im not sure which one to get.
Please let me know which one is more reliable, one that wont mess up the clutch and best tune.
Rebel stage 1 is the best bang for your buck... but you will need more supporting mods, and will be kind of hard on the stock clutch, as it makes more power.
GM S2 is more of a safe route, as it makes less power, and retains your warranty.
do what u want but if i were you i would spend the little extra money for something worth it
i looked at zzp kits and every single one of their kits are with the weak ass 42lb injectors **** that
yes it you get the tune emailed to you for 75 cheaper if not you send them your pcm they flash it ten they send it back or you put down a 100 dollar deposit they send you a pcm when you get it you put it in then you send them yours and you get the 100 dollars back
ok...sweet...well, here is the question, pulley puller included, how much do you think this would total out to? and other than getting that damn pully off, how hard is the actual install?
ok im going to get rebals stage 1. but what type of supporting mods will i need. Also what do i need to do to get into the group buy i saw. How much would it cost with the group buy. im down and ready to get.
Also will the new oem exedy clutch the stock replacement one hold up. isnt it suppose to be stronger then the stock clutch.
Last edited by boricua s/c ss.; Mar 6, 2008 at 09:55 AM. Reason: Automerged Doublepost
