SPEC CLUTCHES and FLYWHEELS!!! Available NOW and on SALE!!!
Old Aug 7, 2009 | 07:28 PM
thmotorsports's Avatar
Exclamation SPEC CLUTCHES and FLYWHEELS!!! Available NOW and on SALE!!!
Backed by popular demand THMotorsports is Bringing SPEC clutches and FLYWHEELS at BEST prices to the Cobalt.net crowd!!!
FREE SHIPPING ON ALL CLUTCHES!!!
***These packages below convert the restrictive and vague factory SAC type pressure plate to a SPEC exclusive 360 degree pivot unit with higher load/rpm ability, better drivability and longer life than can be achieved with the factory design. SPEC flywheel is required to utilize this design.***
SPEC Clutch Kit - Stage 1
The SPEC Stage 1 Clutch Kit is made for bolt on naturally aspirated and mildly modified forced induction engines. Stock-like daily drivability and very good wear characteristics.
High clamp pressure plate, steel-backed and multi-compound woven organic material and high torque sprung hub and disc assembly, bearing and tool kit.
Torque Capacity 335
2.0L Cobalt SS/SC Stage 1 CLICK TO ORDER AND FOR PRICING
SPEC Clutch Kit - Stage 2
The SPEC stage 2 Clutch Kit is perfect for all mild to moderately modified naturally aspirated and power adder engines. (Also good for stock power levels and spirited driving when good daily drivability and extremely long life are the goal.) Stock-like daily drivability and EXCELLENT wear characteristics.
High clamp pressure plate, pure Kevlar friction material and high torque sprung hub and disc assembly, bearing and tool kit.
Torque Capacity 395
2.0L Cobalt SS/SC Stage 2 CLICK TO ORDER AND FOR PRICING
SPEC Clutch Kit - Stage 2 PLUS
The SPEC Stage 2 PLUS Clutch Kit is designed for all modified engines making more torque than the standard SPEC Stage 2 Clutch Kit can support. Maintains stage 2 feel for good daily drivability and offers very good wear characteristics, but provides a higher torque capacity. High clamp pressure plate, composite multi-friction carbon-kevlar material, high torque sprung hub and disc assembly, bearing and tool kit.
Torque Capacity 440
2.0L Cobalt SS/SC Stage 2 PLUS CLICK TO ORDER AND FOR PRICING
SPEC Clutch Kit - Stage 3
For heavily modified street and race engines choose the SPEC Stage 3 Clutch Kit. Offers sufficient daily drivability with a comfortable pedal feel and quick engagement. Offers good wear characteristics under low and high stress usage.
High clamp pressure plate, 4 or 6 puck carbon semi-metallic friction with high torque sprung hub and disc assembly, bearing and tool kit. 6 puck is standard on most applications, but 4 puck can be specified when ordering.
Torque Capacity 495
2.0L Cobalt SS/SC Stage 3 CLICK TO ORDER AND FOR PRICING
SPEC Aluminum Flywheel FOR USE WITH ALL CLUTCHES ABOVE
SPEC Flywheels are CNC manufactured at an unheard-of .001 tolerance, in an industry where the standard is .010. This precision manufacturing process ensures perfect balance and a perfectly flat bedding surface for the clutch disc, both of which also contribute to the ultimate in safety for competitive environments. All SPEC flywheels carry SFI certification.
The automotive component most responsible for insuring optimum clutch performance and life is the flywheel. The flywheel’s contribution to power transfer is three-fold.
Firstly, the flywheel should provide a consistent and friction enhancing surface for the clutch disc. Flywheels also aid in proper inertia, which is determined by the flywheel weight. Inertia controls the ratio of power to acceleration and can make a vehicle faster or slower based on gear ratio, tire type, vehicle weight, power output and even the location in the powerband output is achieved. The weight of a flywheel and amount of inertia it provides can also effect drivability. Lastly, the flywheel must provide a true balance at rpm, which means no dimensional runout that produces engine damaging and power robbing vibrations and allows smooth engine revolutions.
To allow for specific inertia needs, SPEC flywheels are made in high carbon billet steel and aircraft quality billet aluminum. The aluminum and most steel SPEC units are rebuildable and feature a replaceable steel friction plate that is made from a friction- enhancing steel metal specially formulated for optimum clutch bedding and holding power. The aluminum and steel materials provide a light and medium weight option for all types of racing. SPEC spends a lot of time and effort on research and development of optimum flywheel dimensions and weights for all types of driving and racing and can optimize your MOI (moment of inertia) to maximize your car’s output and performance.
2.0L Cobalt SS/SC SPEC Aluminum Flywheel CLICK TO ORDER AND FOR PRICING
PM US FOR ALL COMBO DEALS!!!!
IF YOU ARE RESURFACING THE OEM FLYWHEEL BELOW ARE THE CLUTCHES FOR YOU:
2.0L Cobalt SS/SC Stage 3 PLUS CLICK TO ORDER AND FOR PRICING
FOR THE 2.2L/2.4L BASE, LS, LT, LTZ, SS COBALTS, HERE ARE THE CLUTCHES THAT ARE AVAILABLE
2.2L/2.4L BASE, LS, LT, LTZ, SS Cobalt SPEC Clutch Kit - Stage 1 CLICK TO ORDER AND FOR PRICING
2.2L/2.4L BASE, LS, LT, LTZ, SS Cobalt SPEC Clutch Kit - Stage 2 CLICK TO ORDER AND FOR PRICING
2.2L/2.4L BASE, LS, LT, LTZ, SS Cobalt SPEC Clutch Kit - Stage 2 PLUS CLICK TO ORDER AND FOR PRICING
2.2L/2.4L BASE, LS, LT, LTZ, SS Cobalt SPEC Clutch Kit - Stage 3 CLICK TO ORDER AND FOR PRICING
SPEC Clutch Kit - Stage 3 PLUS
2.2L/2.4L BASE, LS, LT, LTZ, SS Cobalt SPEC Clutch Kit - Stage 3 PLUS CLICK TO ORDER AND FOR PRICING
IF YOU GUYS NEED ANYTHING ELSE SPEC CLUTCH RELATED OR FOR ANY OTHER APPLICATIONS CALL US OR PM US!!!
Call us or PM us for COMBO DEALS!!!
How to order?: Call us at 1-800-959-0145
We also offer Google checkout and PayPal!!! Send us your email and we will send you a checkout request
Call 1-800-959-0145 toll free and mention the sale
**Master Card, Visa, Discover, AMEX** OR PM US!!!!!!!
EMAIL: adamk@thmotorsports.com
WE ALSO USE AIM: adamkthm
Old Aug 10, 2009 | 01:43 PM
thank you for the orders guys!!!
Old Aug 10, 2009 | 02:22 PM
freakta's Avatar
sub'd for later... need a clutch for tranny install
Old Aug 12, 2009 | 10:46 AM
freakta's Avatar
pm'd and sub'd
Old Aug 12, 2009 | 04:08 PM
all PM's responded to!!
PM us for insane combo deals!!!
Old Aug 19, 2009 | 01:26 PM
thank you for the orders!!!
Old Aug 25, 2009 | 05:02 PM
Check out this special!!!
Old Aug 28, 2009 | 02:32 PM
Thank you Maurice for your order of the stage 2!!!
Old Sep 4, 2009 | 11:50 AM
Thank you for the orders guys!!!
Adam
Old Sep 4, 2009 | 11:53 AM
Black08SSTC's Avatar
anything for the cobalt TC?? 08-09
Old Sep 4, 2009 | 02:57 PM
I haven't had hands on experience yet with the 08+ drivetrain but I believe SPEC can build it.
They are usually pretty good about that.
Adam
Old Sep 9, 2009 | 03:22 PM
PM us for combo deals!!!
Old Sep 9, 2009 | 03:37 PM
06_SIC_SS's Avatar
quick question.. are the spec stage 1 and spec stage 2 clutches good for use with the stock flywheel?? cuz the prices are pretty damn good..and my stock clutch is likin to slip a bit with the TVS..
Old Sep 11, 2009 | 12:19 PM
they have 2 kinds of clutches!!!
ones that need their flywheel and ones that reuse the stock one.
give me a call or follow the link to purchase the correct one based on your needs.
Thank you
Adam
THM
Old Sep 11, 2009 | 03:17 PM
conerboner's Avatar
is their a clutch for the 2007 2.2
Old Sep 14, 2009 | 07:10 PM
yes sir!!!
http://www.thmotorsports.com/spec_clutch/b-10213.aspx
plug in your car in the top right and there ya go!!!
Adam
Old Sep 16, 2009 | 02:40 PM
Old Sep 21, 2009 | 07:33 PM
PM us with your needs!!!
Old Sep 29, 2009 | 12:54 PM
Thank you very much for all the orders!!!
Old Oct 9, 2009 | 03:47 PM
We will beat any price!!!
Old Oct 9, 2009 | 08:30 PM
NWAE Cobalt's Avatar
for a 2.2, which clutch would be best for a street driven high HP N/A build? you dont have the max tq specs listed on the site
Old Oct 10, 2009 | 12:43 AM
ION/GONE's Avatar
How much for the spec aluminum flywheel part # SC07A for the spec stage 2+ SCO73H? PM'ED
Old Oct 10, 2009 | 02:23 PM
Omnigear's Avatar
how many miles are the spec fw rated at? is it close to the stock
fw, pm me for the stg2+ with fw
n the stg2+ with stock fw please.
Old Oct 10, 2009 | 02:33 PM
~Mike~'s Avatar
sub'd. I'll be buyin in about a month. All the good sales always happen before I can afford them lol
Old Oct 12, 2009 | 04:18 PM
yeah we put on our site whatever was current with SPEC.
Call SPEC up and they can assist you with the exact numbers and let you know what woudl be the best clutch to go with.
you got PM!!!
PM me or call me. Need to know what car trim you have. Miles depend on the abuse you put it through and basically how you drive it.
Let me know sir!!!
Adam
THM
