need help fast!!
Old Feb 26, 2011 | 10:49 AM
rekameohs_nire's Avatar
need help fast!!
well im trying to get ready to go home to pa for spring break and last night the car starts running like ****. this morning i checked my interceptors and got the codes P0171, P0300, and P0326. the idle surges and it wont really let me drive it anywhere. please help
Old Feb 26, 2011 | 10:51 AM
Chevycobaltss3's Avatar
check your maf snesor and air filter for dirt.
Old Feb 26, 2011 | 10:57 AM
i just cleaned the maf and the filter like 2 wks ago
Old Feb 26, 2011 | 10:59 AM
ujustgotshook713's Avatar
fuel pump priming ? make sure the filter isnt hanging off the CAI...sounds like the same problem i use to have, until i found out there was a hole rubbed into my shitty first cold air intake, so i got the Injen as well...
Old Feb 26, 2011 | 11:03 AM
how do i check if the fuel pump is priming... and the filter is def on there
Old Feb 26, 2011 | 11:35 AM
first off all the codes would consist of a misfire, p0300 is a random misfire, p0171 is a lean code, and p0326 is a knock sensor issue, prob from the misfire, you are detonating, so you prob got bad gas. get you some sea foam, put it into the tank, get you some 93 from like shell or bp. and run it without getting on it, then go for a ride but before you do this disconnect the power wire from the batter and negative, touch them together for a sec and let the car sit for 10 min, then put it all back together then go see if t goes away.
Old Feb 26, 2011 | 11:42 AM
i always run shell 93 and i just cleaned the maf sensor and it still is doing it... this is what idle sounds like
Old Feb 26, 2011 | 11:48 AM
take your throttle body off and clean it. Also check for a vacuum leak. you either have bad gas which is causing your issue, 2 your maf got somthing on it even tho you cleaned it it is still there, 3 your tune is far off, 4 your o2 sensor is screwed, check for the wire to make sre its not grounded ouyt on the exaust manifold.
Old Feb 26, 2011 | 01:55 PM
Coblasts's Avatar
Lean code,got to have a leak somewhere .check the cai where it passes by the rad support.
Check vacuum hoses etc.
Old May 5, 2026 | 10:54 PM
Rubenguz123's Avatar
What was the fix ??
Oct 27, 2015 01:27 PM
OrangeCoba
Sep 29, 2015 03:56 PM
Sep 27, 2015 08:53 PM
no_ss
Sep 18, 2015 11:03 AM
