Old 04-26-2018, 07:16 PM
  #14451
StevoElSupremo's Avatar
Originally Posted by Johnny Bliss
picture?
Eh its 60 floors down in the parking garage lol this is a pretty common mod though
Old 04-26-2018, 09:08 PM
  #14452
I actually bought the factory kit years ago. One of the best mods I ever did.
Old 04-27-2018, 08:10 PM
  #14453
Gregh92's Avatar
Zzp intercooler kit and dyno tune
Went to ZZP today. Had them install large size intercooler upgrade package then do a dyno tune. 310whp and 335 ftlbs torque on 93 octane.
Old 04-29-2018, 05:28 PM
  #14454
Henry3959's Avatar
Received all the specs back from the machine shop on the LEA block I purchased.
First off this was only suppose to have 20,000 miles on it. I was thinking a de-glazing is all that would be needed and a taper under .0004" Standard is 3.4645 so something under 3.4649
I get it with a reman plug on it so off to the machine shop it goes to see what all was done to it. First thing I noticed is one of the OEM oil galley plugs on the back was replaced with a bolt and an oil return hole was drilled and tapped into the filter housing. Indications of a turbo feed and return.
The initial good news was the bore had not been altered. The bad news was the Taper was 13X the allowable limit. Yes, 13 times. Since the LEA sleeves are not removable like the LE5 and others, It took a cut and hone to 3.4700 to perfect all the holes. So I have zero taper now and a letter off to Diamond to take my last specs and increase them to what's necessary.
There's quite a financial difference between a de-glazing and cutting and honing 4 holes. It wasn't done there. The block took .010" off the deck to get it clean. My head already took .010 to take care of warping. That means a .040 Cometic gasket. Overall that will make clearance .007 closer but their next jump is an .080 gasket. The LSJ and others have way more choices.
After Diamond gets back to me I want to discuss lower compression pistons for a higher future boost.
Old 04-29-2018, 09:14 PM
  #14455
Henry3959's Avatar
My new favorite color for Aluminum parts.
Old 04-29-2018, 09:27 PM
  #14456
That looks nice
Old 04-29-2018, 11:33 PM
  #14457
That sure looks nice what paint is that?
Old 04-29-2018, 11:59 PM
  #14458
Henry3959's Avatar
Super Chrome Powder Coat. Not exactly mirror chrome but a killer polished aluminum look.
I don't paint anything that can be taken apart and withstand 400F anymore.
It's the recommended base coat for translucent colors or stand alone for a chrome look.
Old 05-02-2018, 01:21 PM
  #14459
chris88z24's Avatar
I might actually put the summer tires on. Can't believe there's still snow on the ground in spots.
Old 05-05-2018, 10:12 PM
  #14460
Henry3959's Avatar
Machine shop finished fixing the block.
Decked 0.010
Cut and honed to 3.470
Turned crank mains and rod journals .010 under
Milled head
Starting to mock up brackets etc. so there are no surprises later.
Old 05-07-2018, 08:29 PM
  #14461
Replaced the driver side caliper since it wasn't working for the ebrake no more and my car was moving on inclines
Old 05-07-2018, 09:12 PM
  #14462
chris88z24's Avatar
Gave it a wash after work. Cleaned the undercarriage and inside all jambs. Some rust starting on the passenger rocker, looks like it's time to por 15 that and spray oil inside the rockers.
With that said, she still cleans up nice after 11 years and 142,000 miles.
Old 05-08-2018, 12:44 PM
  #14463
Northindy's Avatar
Hit a milestone last week. 100K.
Old 05-08-2018, 02:09 PM
  #14464
Nice! Just got it broke in.
Old 05-12-2018, 12:48 PM
  #14465
Jesse's Avatar
Got it running again after a fuel pump hot-wiring.
Originally Posted by HGT
Milled head
How much you have the head milled? I had them mill mine .030" and they looked at me like a psychopath
Old 05-12-2018, 02:24 PM
  #14466
Henry3959's Avatar
Only what was necessary to correct warpage. .010.
030 will raise your compression about 1/2 a full point
Old 05-12-2018, 02:29 PM
  #14467
Jesse's Avatar
That and the thinner lsj gasket was my intention. If all goes well I want to dyno it. See if I can make 200whp na on ethanol. If the head gasket isn't sealed it's off to the scrap heap.
Old 05-12-2018, 02:33 PM
  #14468
Henry3959's Avatar
Was the block straight? They had to take .010 off of mine to clean it up also.
Old 05-12-2018, 02:40 PM
  #14469
Jesse's Avatar
Don't know. It wasn't supposed to be this complicated. First it blew the oil out and spun a bearing. Crank had no damage so it was supposed to be an easy fix. Then the timing guide broke and I said **** it, may as well throw that ported milled head on it if I'm changing the timing set. And balance shaft deletes. And may as well do head studs.
Old 05-12-2018, 10:21 PM
  #14470
Jesse's Avatar
Broke it again. this time it's gone for real. Selling it probably to a junker
Old 05-12-2018, 11:23 PM
  #14471
Lol what you do to it?
Old 05-12-2018, 11:30 PM
  #14472
Jesse's Avatar
Got it running and revved it a little. It jumped two links on the timing chain. Chain has 1/2" of play in it. Rattles more than a graffiti artist with Parkinson's. And the valves are most certainly fucked. Im not pulling the engine a third time or spending another dime on it. I have a 68 beetle to restore **** this car
Old 05-13-2018, 12:21 AM
  #14473
Lol well that will do it for sure
Old 05-13-2018, 11:06 AM
  #14474
That sucks
Old 05-13-2018, 08:38 PM
  #14475
Henry3959's Avatar
Started the block blue printing yesterday.
Milled and tapped the head for the correct size intake bolts. No more wimpy LE5 bolts.
Opened the head for the PCV. No longer need to modify gaskets and i didn't want to channel the ZZP Pheonolic spacer.
Opened up the PCV valve holes 25%
Quick Reply: What Have You Done To Your Cobalt Today?
