For Sale Supercharger Kit, Lsj head Ported M62, More
[SIZE="3"]][SIZE="3"]Complete Supercharger Kit Sold
LSJ Shortblock $600 plus shipping
Nice Complete LSJ Head $350
Partial Supercharger Kit $450
New LNF Cams. $80
Pro F35 Clutch Line up tool $25
More To Come
LSJ Coil Packs $75
Perfect 5th gear assembly $100 Shipped
Input shaft and cluster. Looks like new. $100 shipped
Main shaft cluster complete. $100 shipped
New LNF Flywheel $90 Shipped
2007 auto trans 1894 miles $200 Cobalt - G5 Pending
new LNF Pan $80
Spare set of LNF hubs drilled for 5X114.3 bolt pattern .Includes stock studs $320 Shipped
New LNF Cams. $80
More To Come
LSJ Coil Packs $75
new LNF Pan $80
New SS TC bumper cover $300 picked up or I can meet partway for gas money.
Nice LNF rotating assembly $175 Shipped
Rod and main bearings Std $70 shipped
New Turbo Heat Shield $25 shipped
F35 3.82 ring and pinion $40 shipped
LNF Steering Column center with key $75 shipped
Stock LNF Clutch Kit good used condition $100 Shipped
New Cable Clamps $25 Shipped
Nice used Waterpump with gear $30 Shipped
2.2 VVT head w valves and springs $125 Shipped
LNF Injectors $25 EA shipped
Stock Bypass Valves $25 Shipped
LNF Fuel rail $30 Shipped
KO4 Compressor housing w extras $50 shipped
[/SIZE]
Nice set of tails $90 shipped
3rd Brake light $35 Shipped
Lower charge pipe like new $50 shipped
LSJ Cooland pipe ,Thermostat housing, oilcooler with rad hose and other hoses $85 shipped
LSJ engine wiring harness and ECU $200 shipped Will seperate
Ill be out of town that weekend. 5th thru 7th. Be back Sunday around noon so if your still here at that time we can do it. Ill have to drain the fluid so you dont trash you car. We can put some cardboard in the trunk and a couple contractor bags around the trans. I might be able to get back sooner.
