For Sale Mongos Stars & Stripes Sale
Old May 24, 2014 | 12:20 PM
mongorat427's Avatar
I have Waaaaay Too much so here goes
Sleeved Block with Diamond pistons $1200 plus shipping
ZZP LNF Fueling Cam $165 shipped
F35 install kit $65 shipped .in cludes crush sleev /Spacer and pinion nut
Very low mile LSJ timing sets $60 shipped. One with balance shaft bearings and gears. $75
LNF disc new $50
LSJ Injectors $70 with rail and wiring. Without rail $60 without wiring $50
New style 2010 and up KO4 .$250 I have several of these
Very Low mile timing covers $50 each
Heat Exchanger pumps $60 shipped Tested
Manifold mounting bracket with heat exchanger bracket $75 shipped
Idler $40
Very rare fuel line clips. 3 for $10. These also work in the LNF valve cover lines
Manifold bracket $25 shipped
Heat Exchanger brackets $40
LOW Mile LNF LE5 LEA LDK Lap EtcEtc Coils $50 a set shipped
LSJ Coils with harness $50 a set
LSJ Blocks $300 plus shipping
LNF style Piston oilers $65 for new ones and $40 for used
LSJ Cams $60
Old May 24, 2014 | 12:31 PM
06cobaltncng's Avatar
I wish I was rich
Old May 24, 2014 | 12:44 PM
4.45 gears $450 Last set
Lsj Balancer .Like new $25Name:  DSC_0038_zpsedc6d12f.jpg
I have 5 nice LSJ heads. A couple of them are like new $400 , Nice used over 50000 mile ones $275 shipped
LSJ Pans very clean $50 I have LNF LE5 2.2 style also
2.4 6 pin throttle bodies $50
Used HPFP LNF $75
Sensors/coils Etc
Used brembos with lines $250
Balance shaft delete gears $30
Shifter Cable clamps $25 a pait
VVT Sels Low miles $30
2.4 Rotating assembly $175 Cranks $75 . Rods and pistons $75
Old May 24, 2014 | 01:11 PM
tuned08ss's Avatar
Whats needed to get those 4.45's to work in my lnf?
Old May 24, 2014 | 01:16 PM
LSJ Valve Covers $45 shipped . I have 10 of these
Lsj headers $40 shipped I have 10 of these also
LNF piston oilers. A must for forged pistons new $65 a set Used $45 a set
LNF Manifold $75
Good clutch and pressure plate $50
Manifold Spacer LSJ $25 shipped
New Coolant Filler pipe with cap $40 shipped. Without Cap $29
Tensioner and bracket $100 shipped
Meth plate $20
LNF shift cable bracket $20
Good Boost Actuator M62 $75
New LSJ Valves $120 for all 16
New LSJ TB $110
A good transmission man to install them
Last edited by mongorat427; May 25, 2014 at 01:07 PM. Reason: Automerged Doublepost
Old May 24, 2014 | 02:25 PM
Quad-coupe07's Avatar
How the cylinder wals look on those lsj blocks for 300?
Old May 24, 2014 | 02:35 PM
Most need bored or honed.
Old May 25, 2014 | 01:36 AM
badjuju's Avatar
Any FE5 lower control arms ?
Old May 25, 2014 | 02:40 AM
cobaltss#01's Avatar
this is probably a dumb question but will the LNF manifold work on the 2010
lnf and if so how much shipped to 17957?
Old May 25, 2014 | 04:04 AM
Got one that just needs a hone? Dont wanna mess with trying to get it bored :/
Old May 25, 2014 | 06:22 AM
None sorry
Old May 25, 2014 | 06:23 AM
Yes their the same $75 shipped
Old May 25, 2014 | 06:25 AM
Ill check . I might have one if your going to used forged pistons
Old May 25, 2014 | 06:09 PM
ezjarecki's Avatar
will those balance shaft delete gears work in a 2010 2.2 lap?
Old May 25, 2014 | 06:14 PM
sLAsh's Avatar
How much to ship to Canada via USPS so I don't get raped by those bastards at ups?
Toronto, Ontario
Old May 25, 2014 | 08:14 PM
Interested in the LNF mani if the other guy doesnt want it. PM me your paypal and i'll send the money and shipping address
Old May 25, 2014 | 08:22 PM
Toronto, Ontario
I think the flat rate envelope is $20
Old May 25, 2014 | 08:27 PM
Yes you will still need the level Zero bushings
Old May 25, 2014 | 09:34 PM
Money sent for LNF intake mani
Old May 26, 2014 | 06:17 AM
Thanks going out Tuesday Still have one left
Old May 28, 2014 | 06:32 AM
I have 2 blocks with very nice cylinder walls
Old May 28, 2014 | 07:53 AM
NVR2FAST's Avatar
I want the lsj manifold spacer
Old May 28, 2014 | 11:37 AM
Sold 20 minutes ago Sorry
Old May 28, 2014 | 04:04 PM
Freakystyley's Avatar
Do you happen to have a Supercharger bypass solenoid?? Missing mine from my rebuild lol
Old May 28, 2014 | 06:07 PM
Thats the one connected to the Purge evape on the back of the head
