For Sale NoorJ's partout: turbo kit, engine parts, lots more
Old 08-08-2014, 11:04 PM
noorj's Avatar
Well guys, as some of you know the time has come. I learned a lot from some of the better guys in this community and I would really like to thank you. I had alot of fun with this car, and I will certainly miss it but it's time for me to get into the turbo lsx game.
All prices are + shipping and paypal fees unless stated, prices are firm but feel free to make offers. Please ask any questions you have in the thread so others can see the response.
Turbo Kit- $2000 SHIPPED/$1900 picked up or $2750 with the Borg Warner s261et I made 320/299 on the comp 5556 setup on 9 psi, search for info on the 261- it can do alot
100% complete kit with Comp 5556 turbo with .48 and and extra .82 a/r housing, 8k miles no shaft play but I would rebuilt it just to be certain your call tho
All other turbo parts have 12k on them
4 bolt to v-band adapter for .48 a/r turbine housing
3” v band clamp
Custom 3” catless downpipe with 2.5” 2 bolt exit flange, 2 o2 sensor bungs (can include 3 bolt flange for LNFs) may need slight modification depending on your mount setup/turbine housing selection
ZZP cast stainless steel turbo manifold with bung for egt probe and DEI titanium heat wrap
Precision turbo 44mm wastegate with all springs from 4-20psi
Custom 1.75” stainless steel dumptube
Custom 2.5” aluminum hot side charge piping
All silicone couplers needed and with all t-bolt clamps
ZZP 50mm blow off valve with two springs
Treadstone TR8 intercooler
Custom 3” cold side charge pipe with maf pad+maf sensor
Treadstone air straightener welded in cold side charge pipe
FID vacuum distribution block
Silicone vac lines for boost controller, boost gauge, bov and evap
Hallman Pro manual boost controller
ZZP turbo oil feed and drain kit, everything you need!
Ecotec oil pan with oil drain bung welded in (5qt) works with any engine
Custom 3.5” aluminum intake with huge K&N filter and port for pcv
Oil cap breather
Maf extension harness
(4) NGK LFR6A-11 plugs, brand new and I’ll even gap them for you
(2) ZZP 2 bar map sensors, just in case
Modern performance oil catch can with lines
All hardware and gaskets, but some gaskets shouldn’t be reused- your call tho
Can tune it for you also, pm to discuss
AGP Borg Warner s261et, 4k miles, great condition with .63 a/r vband turbine housing- $900
ENGINE PARTS
ZZP 2.4 ecotec connecting rods, brand new never used- SOLD
Balance shaft deletes, never used- SOLD
LE5 bare head, ported slightly on intake and moderate on exhaust- $0
LE5 Valve covers, polished or painted plack- $25
ARP timing chain guide bolts, brand new never used- SOLD
Performance autowerks racing 75# valve springs, brand new never used- SOLD
Other stuff
complete OTTP RSFS with stainless braided lines, fuel filter, fittings and fuel pressure gauge, with lsj fuel rail. Literally everything you need to run it, About 4k miles on it- $250, or with 80’s for $350
Also have an AEM 320 e85 pump in an already modified canister so it would be 100% drop-in, whole setup for $500
Siemens/mototron 80# injectors (zzp) about 10k on them- $125
Saab lk9 intake manifold with throttle body gasket- SOLD
LE5 valve cover powder coated candy raspberry- $40
Powell hardcore rear sway bar powder coated candy raspberry- SOLD
Powell F23 front rotated engine mount with LNF rear mount- SOLD
Blown FE5 struts+shocks with Powell YYZ v1 springs- $100
ZZP ecotec turbo 3” downpipe with 2.5” 2 bolt exit, 3 o2 bungs for primary, secondary and wb- SOLD
ZZP 3 pillar gauge pod- minor scratches from filing to fit aem boost gauge- SOLD
PLX Exhaust gas temperature gauge w/ thermocouple- $50
TWM delrin lined hybrid m1 abhrams knob- $75
TWM F23 short throw shifter with candy blue powder coated m1 abrams knob- $150Name:  IMG_1763_zps7ae546c0.jpg
AEM wideband, lots of miles but still functions great- $100
Aeroforce Interceptor scan gauge for 2.2/2.4/LNF in black/white- SOLD
’06 LSJ 160mph gauge cluster- works with any ’06 cobalt- $40
LSJ a pillar gauge pod- $20
Depo gen 4 headlights, black in alright condition with ddm 6k hid bulbs and ballasts- $75+stock headlights
Good condition coupe tail lights, unknown miles- $20
LOCAL PREFERRED- can meet up near metro Detroit or buffalo ny
Ion Redline Recaro seats wired for cobalt weight detection bag, decent condition- $150+trade for any cobalt seats
Magnaflow catback, 30k miles surface rust but it’s stainless- $100+your stock 2.2/2.4/lsj catback
Wingless Laser blue metallic trunk, debadged, unsure of mileage but good condition- $250
Saab 9-5 Aero BBS 17x8” wheels with Dunlop star spec z1 tires, tires have 5/32” front and 3/32” rear- $250
Hoosier DOT drag radials (cheater slick) 225/45/17 on Malibu steelies- $200
As you can see some stuff is still on the car, but everything will be removed by tomorrow 8/9. I will get all remaining pictures then, i know the rules but its just alot of pics all at once and photobucket is cooperating well.
noorj is offline
Old 08-08-2014, 11:52 PM
Got Bewst?
Bluelightning's Avatar
Sorry to see ya go man. Hella sweet part list you have though! Fak I wish I lived closer. I'd be all over the seats.
Bluelightning is offline
Old 08-09-2014, 12:10 AM
andrewcarr1993's Avatar
I'll probably take the springs and RSFS, I'll let you know for sure as well as the seats. I want them, but then also want the SS/TC seats or possibly R100's so I need to make a decision.
andrewcarr1993 is offline
Old 08-09-2014, 12:16 AM
noorj's Avatar
Thanks man, yeah its definitely hard to move on but I'll still stick around the forum. I tried taking all the parts off earlier this week, couldn't bring myself to do it so I went out for one last nice highway blast lol
Sounds good man. If your gonna be doing any hpde's or alot of autox go with r100's
noorj is offline
Old 08-09-2014, 12:23 AM
SLRdohc's Avatar
Will those slick setup clear tc brembos?
SLRdohc is offline
Old 08-09-2014, 12:26 AM
noorj's Avatar
I don't know, they clear my ss/sc brakes by a mile. I'm sure with a small spacer they would, maybe they would without.
noorj is offline
Gelladuga69's Avatar
Sorry to see that the locals are too cheap
They're all too concerned with their grand sport stripes and powder coated wheels.
Gelladuga69 is offline
Old 08-09-2014, 12:28 AM
noorj's Avatar
lol its alright, I really thought that local stuff would sell tho im not asking much for it
noorj is offline
Old 08-09-2014, 12:31 AM
Priorities. Stickers > Any real mods
Old 08-09-2014, 02:07 AM
k9redline's Avatar
pm'd
k9redline is offline
Old 08-09-2014, 02:22 AM
Do the seats include the back seat?
Slowbalt2000 is offline
Old 08-09-2014, 09:55 AM
noorj's Avatar
Yes they would, again would need your stock seats front+back
noorj is offline
Old 08-09-2014, 02:38 PM
SPOOLING's Avatar
PMed
SPOOLING is offline
Old 08-09-2014, 02:49 PM
574's Avatar
Can't wait to see whats next man. Didn't realize you had so much **** haha, this thread looks a lot like one I sense coming up! Kinda surprised there isn't more action in here...
574 is offline
Old 08-09-2014, 03:47 PM
noorj's Avatar
I've got my eye on a couple potential cars, no matter what chassis itll have >400ci and a fat old turbo
And yeah hopefully it picks up soon.
noorj is offline
Old 08-09-2014, 04:20 PM
Bass_Waves's Avatar
Wow really. I just bought the ottp return style a week ago. FML!
That trunk though . where u located
Bass_Waves is offline
Old 08-09-2014, 05:41 PM
noorj's Avatar
Metro Detroit, but I will be in Buffalo NY aug 21-24
noorj is offline
Old 08-09-2014, 05:54 PM
06cobaltncng's Avatar
Just an FYI for those interested, those slicks have only a few passes on them, plus w.e Noorj put on them. and they will clear brembos with I think an 18mm spacer.
06cobaltncng is offline
Old 08-09-2014, 06:18 PM
noorj's Avatar
Thanks man! I put a total of 6 passes on them lol
noorj is offline
Old 08-09-2014, 06:26 PM
Viperoni's Avatar
Is that a Lemon Shandy?
Viperoni is offline
Old 08-09-2014, 06:39 PM
noorj's Avatar
haha yeah its my buddies, im a strictly blue light guy
noorj is offline
Old 08-09-2014, 07:35 PM
noorj's Avatar
sway bar sold!
noorj is offline
Old 08-09-2014, 09:56 PM
noorj's Avatar
Powell f23 rotated mount and lnf rear mount
can't fit any more pics in the original post lol
noorj is offline
Old 08-09-2014, 10:18 PM
Pitbull2o08's Avatar
Good deal for F23 guys! Costs 225 new for all that
Pitbull2o08 is offline
Old 08-09-2014, 10:23 PM
South Central *********
JapEatr's Avatar
Will you part with the Hallman?
JapEatr is offline
Quick Reply: For Sale NoorJ's partout: turbo kit, engine parts, lots more
