What Spark Plugs Should You Use On LNF?
Old 06-12-2016, 11:28 AM
tomj77's Avatar
This question has been asked so many times, so I'm just gonna make this a sticky.
Stock Ac-Delco Plugs Gapped to .032. 41-108. 4 Of Them.
Old 06-12-2016, 08:40 PM
Omiotek's Avatar
Ngk makes a good iridium plug. Thats all i run
Old 06-13-2016, 07:23 AM
Administrator
Administrator
Staged07SS's Avatar
Stock AC Delcos are made by NGK.
Old 06-13-2016, 07:24 AM
Omiotek's Avatar
Yes i know. I usually run a step colder. Forgot to mention that. I also usually run higher boost then most
Old 06-13-2016, 07:55 AM
Administrator
Administrator
Staged07SS's Avatar
Old 06-13-2016, 01:48 PM
tomj77's Avatar
I run 28 psi and I use stock. I used one step colder once, engine sounded gurglly
Old 06-14-2016, 03:12 PM
ionRL_585's Avatar
Just did mine and went with stock Acdelco's.
Old 06-14-2016, 06:08 PM
63 Nova SS's Avatar
Those seem to be the best for most anyone. Pay attn to the gap.
Old 06-14-2016, 06:23 PM
ionRL_585's Avatar
Indeed. Mine were off right out of the box. Use a feeler gauge.
Old 06-16-2016, 10:08 AM
umrdyldo's Avatar
Mine were all 030-032 out of the box so i didn't touch them. Quick install. Too bad I found oil on one plug during removal. No misfires or running rough. Hopefully just a spark plug well gasket.
Old 06-19-2016, 07:58 PM
tomj77's Avatar
compression test
Old 08-22-2017, 03:35 PM
Carter Tuchscherer's Avatar
Is there a 1 step colder option anywhere?
Old 08-22-2017, 04:06 PM
For lnf just the oem plugs
Old 10-13-2018, 02:20 PM
CobaltSS313's Avatar
So are copper plugs a thing of the past? i know iridium plugs last longer. I just always bought copper plugs for my LSJ, i just assumed it would be the same for the LNF because they burn better and have better conductivity.
Old 10-13-2018, 06:15 PM
Nothing works better than OEM plugs for a lnf. Also sometimes its best to re-gap them to .032-.030 to avoid spark blowout when tuned or are tuned
Old 10-13-2018, 06:17 PM
63 Nova SS's Avatar
He is trying to say you may need to regap plugs to .030.-032.
Snail_SS (10-13-2018)
Old 10-13-2018, 08:33 PM
Ok I’ll take y’alls word for it, i just never used iridium plugs before
Old 10-13-2018, 08:55 PM
yup that just didnt want to give numbers because I didnt remember what it was lol
Old 10-14-2018, 07:17 AM
63 Nova SS's Avatar
Spell check changed your "regap" to "regal", just didn't want him to get confused. I see you edited it.
Snail_SS (10-14-2018)
Old 10-14-2018, 07:04 PM
zeeky420's Avatar
Actually I've seen guys having problems with at the 600whp levels using copper plugs on a lnf and playing with gaps because of spark problems at high levels of boost
Old 04-16-2019, 07:39 AM
tomj77's Avatar
I started using ngk one step colder from stock. Same plug but a step colder. They work very well. Will post the number later
Old 04-16-2019, 10:22 AM
AfterShok's Avatar
What was the reason from going one step colder? Are you stock or running some mods? I just bought the stock ones you posted originally
Old 04-16-2019, 10:46 AM
He has a big boy turbo
Old 04-16-2019, 01:36 PM
AfterShok's Avatar
bet that thing is wicked
Old 04-18-2019, 07:44 AM
tomj77's Avatar
Like he said, big boy turbo with big boy boost lol. Definitely helps with knock in combination with direct port meth. Run 6 degrees timing more with direct port and one step colder vs stock and single nozzle on 94.
Quick Reply: What Spark Plugs Should You Use On LNF?
