I'm thinking I should start a build thread. Guess this is it.
Old 07-27-2016, 07:55 PM
tomj77's Avatar
Well I think I'll start this since I'm doing a new build. Will probably be slow updating but whatever. I'll take a few pics to start with later of what Iv been doing waiting for parts and money for parts lol.
Basically the plan is for a built ldk , details not yet totally worked out on what that will all consist of.
I have finally made my turbo choice and begun to order the parts.
Will be the s257 sxe turbo with all the goodies. Most of the parts should be on their way from zzp later this week, still waiting for order conformation. In the mean time I'm basically doing rust proofing and repairing and replacing a few things. Working on interior as well. Gonna try making a new dash pod setup.
Started this project yesterday. See how it will turn out. Looks good so far. Don't be know if it will make it on new engine, depending on what head I'm getting.
Old 07-27-2016, 08:08 PM
T-fog's Avatar
Inb4anyoneelse lol
So REDD, SO PURDYYYY lol
Can't wait to see the numbers!
Old 07-27-2016, 08:24 PM
tomj77's Avatar
Originally Posted by T-fog
Inb4anyoneelse lol
The numbers will probably take till next year. I'm taking my time lol.
And ya it's nice eh. I'm gonna do the lettering white and the raised area around ecotec black
Old 07-27-2016, 08:49 PM
inb4riceburner
Old 07-27-2016, 09:16 PM
Good luck tom subd for progress
Old 07-28-2016, 08:58 AM
NomoNissan's Avatar
Subd
Old 07-28-2016, 10:08 AM
RyBread761's Avatar
Subd
Old 07-30-2016, 12:25 AM
tomj77's Avatar
Well the white paint didn't stay. Probably didn't let it dry long enough. But I found letting the aluminum show looks better. Much better than grinding it
Old 07-31-2016, 07:50 PM
colodude18's Avatar
Subbed as well. And I like the lettering accent on the VC!
Old 08-01-2016, 06:31 PM
tomj77's Avatar
I'm also doing this
Backside of dash pod. Fiber glassing it in place
Front side of pod.
brxttz (10-20-2016)
Old 08-01-2016, 06:34 PM
tomj77's Avatar
With a combo of epoxy , silicone for a space filler and fiberglass I'm getting this done. Once it's done it should look mint. I did it in a way that I'll have to do very little work on the top side.
Old 08-01-2016, 06:53 PM
Nice I would love to have that
Old 08-01-2016, 07:06 PM
tomj77's Avatar
Well goto auto wrecker and get some extra dashes, they are a dime a dozen. I got like 4 already. And mod it. All I did with this is bought a universal dash mount pod and cut hose in the dash so it just fits through perfect. The hard part is the measurements . Then Dremel the hole and ur half way there.
Old 08-01-2016, 07:10 PM
I'll give it a try, if you could make a kinda how to that would be really helpful
Old 08-02-2016, 02:30 PM
Scythe_Snake's Avatar
nice, looks like mine and Omiotek's dash.sweet stuff.
Old 08-02-2016, 03:01 PM
slapbetcommissioner's Avatar
Have any extra center vents kicking around tom?
Old 08-02-2016, 08:03 PM
tomj77's Avatar
Actually I do
Old 08-02-2016, 08:04 PM
tomj77's Avatar
I'll attempt it
Snail_SS (08-02-2016)
Old 08-02-2016, 09:31 PM
tomj77's Avatar
I won't have pics probably cause I don't have a second pod
Old 08-03-2016, 12:57 AM
Originally Posted by tomj77
Actually I do
My middle one doesn't spin properly up and down. I think the end of the shaft may have broken.
How hard would they be to swap with the dash still in?
Old 08-03-2016, 12:30 PM
tomj77's Avatar
impossible
Old 08-03-2016, 01:01 PM
I'll live with it I guess lol. Why impossible?
What if the headunit was out?
Old 08-03-2016, 10:56 PM
tomj77's Avatar
Nope, there are 4 screws and 2 metal washer things u have to pry off with a flat screw driver. It's actually pretty easy to remove the dash. Take off trim, remove all screws under it, take off apillers then the trim in back that has the light sensor for headlights in it, bunch of screws there. Remove airbag, 2 10mm bolts can be accessed from glove box. Unplug all buttons and such and airbag. Pull out airbag then pull out dash. Takes like 5 minutes
Old 08-05-2016, 04:46 PM
tomj77's Avatar
Was a little afraid of what painting with rocker panel coating would look like, but dang it tuned out great. It coved up all the minor imperfections perfectly. Now I wait 6 hours and paint it. Will look mint.
Old 08-05-2016, 04:47 PM
tomj77's Avatar
Leaves a similar to stock pattern, but a slight rubberized touch instead of hard plastic
Quick Reply: I'm thinking I should start a build thread. Guess this is it.
