Clicking noise from drivers rear wheel
Old 01-24-2017, 02:47 PM
jgerma01's Avatar
Hey guys.....I am getting a weird clicking noise from the drivers side rear wheel with each rotation of the wheel but I only get it when its raining/wet out. Also when I do get it....it stops when I apply the brakes so my first thought of a bad wheel bearing i dont think applies altho not sure.
Any thoughts?
Thanks
Old 01-24-2017, 05:11 PM
CannonBalt's Avatar
Your pads are vibrating, I had the same problem.
Old 01-24-2017, 05:29 PM
cluelessk's Avatar
Mine started doing it after I got my Winter tires mounted. Been driving me nuts.
Mine clunks more than clicks and goes away with slight brake application.
Was starting to think it was my wheel bearing.
Old 02-27-2017, 10:07 AM
Blue24's Avatar
Same here. Mostly when cold and wet out.
Old 02-27-2017, 04:58 PM
mzspd's Avatar
It is the brake pad.. Check your brake pad thickness, mine were still decent but I ended up replacing them and the noise is gone.
Old 02-27-2017, 05:27 PM
cluelessk's Avatar
I think part of it has to do with our craps rear calipers.
Old 05-25-2017, 08:46 AM
jgerma01's Avatar
Someone mentioned vibrating pads.....any fix to this....so strange tho that it only does it when its raining/wet out....
Old 05-25-2017, 09:13 AM
royce777's Avatar
LNF or LSJ?
Old 05-25-2017, 01:10 PM
HooniganRB's Avatar
I've been having the exact same issue for a while now. Kind of glad I'm not the only one, lol. It mainly happens when it's colder and/or, like you, when it's raining.
Old 05-25-2017, 01:14 PM
cluelessk's Avatar
Think I found the issue. Worn wheel bearing. Causing run out so the rotor taps the pads.
Old 05-26-2017, 02:18 PM
royce777's Avatar
If you have a LNF replace all the hardware for the caliper. There is an anti-rattle clip and rubber pieces that wear out and can cause strange noises. Its a cheap and easy fix.
Go on rockauto and order on of the following:
ACDELCO 18K1848X {#19264058}
Old 05-26-2017, 02:40 PM
cluelessk's Avatar
Interesting. Aren't the rubber pieces just dust sheild's ?
Old 05-26-2017, 02:47 PM
royce777's Avatar
which rubber pieces? The rubber boots around the piston, Yes.
But the rubber in the kit I posted, no. That helps with the alignment of the caliper.
Old 05-26-2017, 07:33 PM
tuned08ss's Avatar
If you need a front lnf wheel bearing, I have one for sale. Brand new timken from zzp.
