I need Recommendations for a new clutch
Old 05-21-2017, 08:56 PM
Dany's Avatar
Hi what clutch you guys recommend for a chevy cobalt ss 2010?
Old 05-21-2017, 09:14 PM
Only one thread is necessary. The other has been removed. How much power/what mods does your car have?
zeeky420's Avatar
What do you have done to your car and or near future plans for car that way people or myself can help lead you in a good direction
Old 05-21-2017, 09:22 PM
Dany's Avatar
Ok hahn pipes,k&n intake,zzp intercooler and stock turbo for now.
Old 05-21-2017, 09:29 PM
What are your plans for the future?
Old 05-21-2017, 09:33 PM
Dany's Avatar
hit 400 to the wheels 😁
Old 05-21-2017, 09:36 PM
Dany's Avatar
ZZPerformance recommended me south bend stage 4
but I do not know what to do🙁
Old 05-21-2017, 09:42 PM
Well that's a good clutch to what I've heard, but I don't see why the gmpp clutch shouldn't hold with 400
Old 05-21-2017, 10:00 PM
Dany's Avatar
what about clutch master is good or bad? And where can i buy the gmpp clutch?
Old 05-21-2017, 10:03 PM
Crate engine depot you could get the gmpp haven't heard of that one tbh
Old 05-22-2017, 03:05 AM
Tdubbs's Avatar
Without an actual dyno, and just going off of the mass air flow, my tuner(PWerks) says I'm right about 400whp(give or take a few). I have the GMPP clutch, and so far it holds, but the question is how long it will continue to hold. I do have a slower spooling journal bearing 6758, so that helps, but I decided I'm going to be a guinea pig and keep my clutch/flywheel thread updated as I go along.
Most would recommend Spec, Southbend, and KY. There are people who love what they got, and others that have hated it, but most also have only run one or two of the options. Just remember, without a built trans and/or good driving technique, an aggresive clutch will be your transmissions doom. Not trying to scare you, plenty of good info around here, read up on others experiences too before you decide.
Dany (12-10-2018)
Old 05-22-2017, 08:39 AM
double clutch's Avatar
I have the southbend 4+ with fidanza flywheel for my zfr. Holds great. The pedal just takes some getting used to at first.
Old 05-22-2017, 12:06 PM
Dany's Avatar
ok bro thanks for the advice but south bend stage 4 is an aggressive cluth?
Old 05-22-2017, 12:54 PM
cluelessk's Avatar
There's dozens of threads that answer all your questions. We get this question weekly
Old 05-22-2017, 02:24 PM
royce777's Avatar
I daily my car with a southbend stage 4, no problem
Old 05-22-2017, 03:25 PM
Tdubbs's Avatar
It's not just the aggressiveness of the clutch, but your driving style as well. If you drive sane and smart, you can be fine, but if you bang through the gears constantly with a grippy clutch, you can run into issues real quick.
Big thing is if you really plan to daily it, get a full face clutch and avoid pucked clutches. Pucked clutches don't slip as easily, but that also means they grab harder and faster, putting all sorts of strain on everything.
Again, plenty of threads around here, poke around them all and decide from there based on others experiences on how they are.
Old 05-22-2017, 07:58 PM
Tykuura's Avatar
I heard south bend was the most OEM feeling clutch.. I have their stage 4 and it doesn't feel drastically different than stock
Old 05-22-2017, 10:07 PM
63 Nova SS's Avatar
I have a gmpp clutch with 370whp and while it's a good clutch I don't expect it to last as long as a $700 clutch. So keep that in mind.
Old 05-22-2017, 11:48 PM
06blackbalt's Avatar
I know a car with a gmpp clutch holding great at 480whp
