303 WHP 325 Ft Lbs ---What Clutch ?
Old 06-26-2017, 07:45 PM
SECRETARIAT's Avatar
Hi guys.
Had my 2010 Cobalt SS with 69,000 miles custom tuned on the Dyno. Got 303 HP & 325 Ft Lbs at the wheels. Only owned car about 3 months. Original clutch doesn't seem to like it. Can smell clutch after I drive it hard at all. Also it will slip in 5th gear now if I hit boost at all.
I've been told the tune didn't cause the issue, just exposed a pre-existing issue with the clutch.
Anyway, would a New stock clutch kit handle these power numbers no problem ? ...or do I have to upgrade ?? This is my daily driver so don't wanna lose it's good street manners.
Thanks for any help.
Old 06-26-2017, 09:03 PM
63 Nova SS's Avatar
Crate engine depot- lsj upgrade clutch also called gmpp. Cheapest best clutch you can get and it works on lnf motors.
Btw your torque sounds a little low for being tuned. Who did the work?
Old 06-26-2017, 09:33 PM
Ya was reading about the GMPP last night and was talking to Tom at Crate Engine today. He indicated he still doesn't think the LSJ is any stronger than the LNF stock. He also believes either would be fine for my application.
ZZP did the Dynotune just over a week ago. Car has CAI, upper charge pipe, ZZP intercooler and high flow catted downpipe. It's my daily driver and I quarter mile track it maybe 3 or 4 times a year.
Would the low torque possibly be because clutch was starting to fail then ? ......or maybe they kept it low because of the stock clutch ??
Old 06-26-2017, 09:46 PM
hawkssoccer11's Avatar
The lsj upgrade clutch is an upgrade over an lnf clutch for sure! I have been running the lsj upgrade clutch for almost 80k miles! Tuned on e47 every summer and daily driven! It has yet to slip on me but then again I don't romp on it from say 40mph in 4th gear lol.
Old 06-26-2017, 10:03 PM
Wow, thanks. 80,000 miles and with quite a bit more power than mine. So I should be good, as long as I don't "romp on it" lol
So is it best to just put a new flywheel on as opposed to resurfacing the original ?
And new bolts on the flywheel ??
Thanks.
Old 06-26-2017, 10:21 PM
Tdubbs's Avatar
Thanks.
Grab the GMPP clutch kit, grab an LuK LFW285 flywheel, new flywheel bolts, and you should be set.
Don't bother resurfacing the flywheel.
Old 06-26-2017, 10:42 PM
Ya I was looking at those flywheels, are they a decent product ? Did you use a Luk flywheel ?
Thanks
Old 06-26-2017, 11:38 PM
Thanks.
Yeah man and that's daily driven too haha. If you drive reasonably and get on it within a reasonable rpm you'll be absolutely fine. I go to the track once a year and I've done a **** ton of street racing and it has never failed me once lol.
Just like tdubbs said. Get a new LUK flywheel or go with an lsj flywheel. Buy brand new, don't resurface your stock one.
Old 06-27-2017, 02:48 AM
Tdubbs's Avatar
Thanks
I do, I have that exact combo. Currently holding up to the beating from a Z54 turbo. How long it'll last with the bigger turbo is still debate, but for your setup it should last a long time.
Old 06-27-2017, 08:49 AM
CudaJoe's Avatar
I have about the same power and maybe a bit more torque than you. Still on the stock clutch at 97k miles. Id either go stock or the gmpp clutch. I dont want to experience puck clutches. Full disc for me.
Old 06-27-2017, 09:51 AM
double clutch's Avatar
If you plan on going big turbo in the future, I would go southbend or a ky full face now.
Old 06-27-2017, 10:43 AM
colodude18's Avatar
I ran my stock clutch for several years on stock turbo and full E85, making 359/418, including road track.
Clutch still looked perfect when it came out at ~42K miles (upgraded to CM Stage 4 when going big turbo).
Key is not to go WOT under 3,000rpm. I should add I also never do digs.
Having said that, if you're replacing the clutch anyways, I would definitely upgrade it.
Old 06-27-2017, 12:26 PM
qfe
Old 06-27-2017, 12:31 PM
califcarm's Avatar
My stock clutch with a 150K miles finally starting giving way when I went from GMS1 to self tuned on HPT (23-24psi tune on 93oct). I went GMPP with the ZZP flywheel, new bolts, GM factory hydraulic throwout bearing, and from reading on here I also replaced the clutch pipe and elbow that are inside the bell housing for insurance (not expensive if you are already in there and definitely don't want to pay labor just for those parts later down the road).
7K miles on the clutch and love it. Drives like stock but holds the quick torque ramp that I have in my tune.
edit: I am stock turbo with ZZP IC and upper charge pipe (only because the stockers blew up after a few months!).
Old 06-27-2017, 06:14 PM
Nope, I'm all done with horsepower/torque upgrades, 300/325 is enough for an old dog like myself. Once the clutch is done, just going to focus on some straight line traction (tires, etc). Thanks.
Old 06-27-2017, 06:21 PM
Great info, I will definitely do the bolts, clutch pipe & elbow while we're at it. Thanks.
Old 06-27-2017, 06:24 PM
Great response, thanks guys.
Has anyone out there had negative results from the GMPP combo ? .....not sure if I wanna hear it.
Old 06-27-2017, 06:36 PM
Supercharged06SS's Avatar
I only have good things to say about it, I replaced mine right around 70k as well for the same reason. 10k later no problems and it hasn't slipped at all. This is on a 09 ss with full bolt ons and a tune.
Old 06-27-2017, 06:43 PM
Tdubbs's Avatar
I haven't heard anything bad about it, other than nobody really knows it's upper limit for torque. It's definitley underrated, but by how much is anyone's guess.
So far mine has survived 9k miles on 328/356 from the stock turbo, and so far it's holding up to abuse from a Z54 "6758" EFR. I'm kinda the guinea pig with it at the moment
Edit: Forgot to mention 2 things.
First, if you're happy with the power level you're at, the GMPP kit and a ZZP or LuK flywheel will be more than enough to cover you.
Second, if you want some handling/traction help, I suggest you look into Powell control arm bushings and rotated mounts. Helps with wheel hop and limits movement in the suspension that shouldn't be there, helping to plant the power.
Old 06-28-2017, 09:19 AM
That's what they all say
Old 06-28-2017, 10:19 AM
royce777's Avatar
south bend stage 4
Old 06-28-2017, 05:56 PM
colodude18's Avatar
qfe
Old 07-04-2017, 08:43 PM
KINGMAROSS's Avatar
I'm going to need to change my clutch pretty soon as well, specially after I tune my car. I'm at 155k miles. Where would I find all these products you're listing?
Old 07-05-2017, 02:48 AM
ThePanduuh's Avatar
I am a fairly stock GMS1 owner at 110k on OEM clutch. Starting to slip a little. So I bought OEM clutch and pressure plate, LUK flywheel, OEM TOB, all new TOB bolts flywheel bolts (tty) pressure plate bolts, and a new clutch pipe. I figure I'm pretty much done with power adding for a while, and I DD as well so I didn't want a ridiculous clutch. Also replacing axles, axle seals, and hubs since I'm going to be doing all of this.
Old 07-05-2017, 12:16 PM
umrdyldo's Avatar
Wait why wouldn't you at least get the GM upgraded clutch. It's so cheap. Feels similar Holds a lot more power than stock too.
