Long cranking after fill up.
Old 09-17-2017, 06:51 PM
mxkx250's Avatar
I have an 08 2.0 turbo. I had a CEL on for leak in the purge system and had my canister replaced with the solenoid and new filter. Around this time, after filling up with fuel I have to crank for 15 or 20 seconds to start. Every other time it fires up right away. Any suggestions?
Old 09-17-2017, 08:46 PM
cluelessk's Avatar
Sounds like an evap issue.
They might of installed something incorrectly or a part outs defective.
Old 09-18-2017, 12:25 PM
cobaltssdude420's Avatar
I had that issue after tuning, replaced the Evap solenoid and it was fine. If you can blow air both ways through it she's toast
Old 09-18-2017, 12:49 PM
mxkx250's Avatar
It seems the simplest fix is the one I should have done. I had rusted fuel lines replaced so I had the shop replace the canister and solenoid on it while they were working on it. I will replace the one under the hood myself and try that.
Thanks for the help guys.
Old 10-10-2017, 05:05 PM
mxkx250's Avatar
I replaced the evap solenoid on the engine and it is fine now. I should have done that first but I was having my fuel lines replaced at a shop and I thought that the canister and solenoid on it would be the problem and had them replace it. I thought the simple fix would be too easy to be the problem. Lol
Old 10-10-2017, 07:20 PM
cluelessk's Avatar
People tend to over think things or assume the worst.
Old 10-16-2017, 02:49 AM
rokon340's Avatar
if I could ask how much did it cost to get the fuel lines replaced? mine are rusted out and need to be replaced.
Old 10-16-2017, 06:08 AM
63 Nova SS's Avatar
I've heard if you have a dealer do it it's close to $1,000. Or if they are only bad in the 1 spot behind the drivers door some just splice in flexible fi hose.
Old 10-16-2017, 02:39 PM
mxkx250's Avatar
I bought fuel lines from Rock Auto but the mechanic said they wouldn't fit and he spliced in lines. Mine was bad where it goes up over the exhaust under the aluminum foil heat shield.
Old 10-19-2017, 03:39 AM
rokon340's Avatar
mine are rusted out in probably the same spot. I spliced in some rubber fuel line as a temp fix so I could move the car .seems to be a common place for moisture to accumulate and cause rust on the lines.
