New to the Cobalt world lol
Hello guys my name is Tops, My son killed his 2007 Cobalt SS supercharged at a 191,520 mile and give it to me. Saying dad you put the first175 miles on this it. You said loved the lil car now it your. Kids right hahaha . He got it brand new in 06 with 26 miles on it. And didn't know how to drive a stick (lol). So I drove it home home for him. I rebuild the engine and LOVE the lil CHEVY. Question guys can this lil car be twincharged??? Thanks in advance for any info:
Tops
www.kingoftops.com
Tops
www.kingoftops.com
Welcome.
Yo answer your question it is possible to twin charge if you find parts from the twin charge kits for sale used at this point. That being said it's not really benifitial to do it. A properly setup turbo kit or a tvs 1320supercharger upgrade will serve youfsr better. Traction is already an issue with these cars and twin charging pretty much kills any chance of properly using the power. You can have the same top end power with just a turbo kit and with they way they build boost and the torque curve actually gives you a chance at traction.
Twin charged kits are also notoriously hard to tune for.
Welcome.
YEah it would really depend on your power goals. Tvs is more expensive to make big power with. But if your looking for 350whp or so it's a great option. If your wanting to breach 400whp turbo is definitely your friend as doing so with a tvs is a pretty heavy build.
Are you starting with a completely stock car? If so swapping in the supercharger is as simple as bolting it on and throwing in some different injectors on to keep up with the higher fuel demand. It's also is typically recommended to swap the end plate out on intake manifold to dual pass end plate for better cooling. And I always recommend option B because I think bleeding the air out of the system is hard enough especially without Option B. Depending on what pulley you end up running you may also need to get either an adjustable belt tensioner from ZZP, and oversized tensioner pulley, or a stage 2 shorter belt. You will also need a tune and a wideband sensor/gauge to keep an eye on and confirm your fueling. Oh yeah an step colder spark plugs.
The front two socket head bolts can make you cuss a bit trying to get them on but you can mitigate that issue by installing it with your bumper and radiator out of the way or I like to use socket head bolts with knurling around the circumference of the head so I can thread the bolts in most of the way with my fingers and then tighten them up with an allen wrench that I cut down so it would slide into the bolt easier. While it can be less than enjoyable I don't think it is a big enough deal to be a deciding factor in which route you take. You also may have been reading on the TVS 1900 instead of the 1320 TVS we are referring to.
