atmospheric Bypass valve
Old 12-07-2017, 08:30 PM
05duramax's Avatar
When I bought the car, it all ready had the atmospheric bypass on it. Yesterday I got the code p2261. Now I have found forms saying to by pass the solenoid, and none have photos.
Also, several have said that the car needs to be tuned for it. The car had a trifecta tune. Last weekend I swap out the ECM with one from ZZP. When I order it I did mention it had an external blow off. Is there a chance the swap could of caused this?
Old 12-07-2017, 10:11 PM
cluelessk's Avatar
It seems like the most obvious problem. You can't try swapping back?
Old 12-08-2017, 01:53 AM
slapbetcommissioner's Avatar
You definitely need to be tuned for it. If you don't have a maf relocate your car will hate it as your releasing metered air.
Old 12-11-2017, 06:57 AM
05duramax's Avatar
Well I switch ECM back and after a couple hundred miles no code. So I am assuming it's the tune. The MAF is in the stock location. Can I move it to the intercooler pipe with out a tune?
Old 12-11-2017, 09:02 AM
No, it will run like dog **** and worse than with just a to atmosphere bpv untuned.
Old 12-11-2017, 12:20 PM
user 72239's Avatar
what spring are you running? I ran the yellow spring for about ~1 year on MAF tune and the car ran fine. I know Term had to mess with some **** to get it to run ok. I ended up getting p0101 multiple times so I relocated the MAF.
user 72239's Avatar
oh and he had to delete p2261 for me. thats a bpv "sticking" code.
Old 12-11-2017, 01:04 PM
05duramax's Avatar
Don't know what spring. I believe he told me it was hks blow off.
Old 12-11-2017, 01:23 PM
user 72239's Avatar
nah thats a Forge Atmospheric BOV. its got two springs usually, green or yellow. you'd have to take it apart to know which one you have.
Old 12-17-2017, 11:33 AM
05duramax's Avatar
Well I got around to taking it apart and I have green springs. In the process I found oil in the bottom part of my intake.
Old 12-17-2017, 12:43 PM
cluelessk's Avatar
That's pretty normal
Old 12-17-2017, 01:14 PM
cobaltssdude420's Avatar
Don't worry about that, it's from the crankcase ventilation at the top of the intake.
Old 12-17-2017, 10:18 PM
user 72239's Avatar
Got some blowby. no big deal
get your tuner to delete p2261 or buy a normal BPV
cobaltssdude420
09-12-2017 12:05 PM
cw383
08-28-2013 12:14 PM
BNRacing
120
06-30-2013 01:19 PM
theneelster
09-18-2008 10:30 PM
Quick Reply: atmospheric Bypass valve
