Is there a default Z54 wastegate duty cycle map?
Old 12-12-2017, 04:57 PM
TroyK's Avatar
Is there a default Z54 wastegate duty cycle map for this turbo or is there a method to manually tune for this new turbo?
I'm installing a z54 this week.
Old 12-12-2017, 05:28 PM
There is no manual method (assuming you mean manual as in tuning a carb) you have to use software.
Do you have hptuners?
Old 12-12-2017, 05:44 PM
TroyK's Avatar
Sorry, yes I do have HPT. Manually tune as in logging data & tuning from logs.
Old 12-12-2017, 09:23 PM
Drop the table down to 65ish and then start adjusting up depending on how far away you are from your target boost. Don't make a jump bigger than 10
Old 12-15-2017, 02:08 PM
Rent me! per hour
Area47's Avatar
start at 25% and work up from there.
Old 12-15-2017, 02:11 PM
Do you start at 25 to see what the wastegate pressure is?
Old 12-15-2017, 02:24 PM
hawkssoccer11's Avatar
dont expect a response, he drops by once a month and disappears lmfao hes a hit it and quit it type of guy
Old 12-15-2017, 04:05 PM
I've been around long enough to know thats how he posts (and to know he knows his **** when it comes to tuning), but when he revisits he'll likely respond.
Old 12-18-2017, 09:31 AM
oh i know lol. thats why i said it lol. you and i both know how he is lol. we also know is arguably the best out there lol.
Old 12-18-2017, 10:46 AM
Rent me! per hour
Area47's Avatar
Keep the WGDC low to see where it actually hits at boost wise. Then work up from there. Some BCS setups will run 30 psi on 65% wgdc.
better safe than sorry.
ECaulk (12-18-2017)
Old 12-23-2017, 07:29 PM
TroyK's Avatar
Ok, the next question how do I set all this up to be dialed in?
Are you talking about
Torque Management\Turbocharger\Duty Cycle Corr
or
Engine\Airflow\General\Torque Based\Desired Air Load
maps?
If it is the 1st one, what channels will I need to record for this?
Currently I'm trying the 1st table. I took the desired boost / actual boost & put it on a load% by RPM chart. Am I going the right way? Then once I get my desired boost to match the actual boost. Then start adjusting the DAL table?
wickednick911
10-22-2007 03:05 PM
Bika
07-10-2007 10:54 AM
REDFOCZ
Tuning
06-14-2007 01:41 PM
Doc
Tuning
03-28-2007 10:31 PM
Admiral Jedi
Tuning
11-27-2006 02:35 AM
Quick Reply: Is there a default Z54 wastegate duty cycle map?
