LNF injector type and fuel control system
Old 05-18-2018, 12:22 PM
LSJMiata's Avatar
I have an LNF I wanted to swap into a endurance road race Miata. I decided the factory ECU is too much of a PITA to tune standalone so I'm looking for an aftermarket solution. Link makes a GDI unit but they're not sure if it will work.
Below is their response
"Unknown for that application. At the moment we can only confirm operation on 2 engines the Honda L15 and the MK5 golf.
We would need to see some information on the high pressure fuel pump control and the type of injectors being used. (we are not able to control Piezo injectors)"
Does anybody know have info I can send to them?
If this doesn't work I'm probably just going to build an LSJ/LE5 hybrid and run it with a Megasquirt.
Old 05-18-2018, 12:28 PM
I want to say they're the same as the MK5 injectors as I know the LNF injectors are drop ins for the VAG crowd for bigger turbos
Old 05-18-2018, 12:33 PM
LSJMiata's Avatar
I was thinking it's a Bosch system since the original LNF had a Bosch ecu so that makes sense
colodude18
07-10-2013 02:35 PM
badbaltguy
10-03-2009 02:33 PM
Zooomer
122
04-07-2009 06:52 PM
L.P.
01-17-2008 01:56 AM
Quick Reply: LNF injector type and fuel control system
