lnf Fuel pressure
Old 11-03-2018, 03:45 AM
Badbowtie's Avatar
lnf Fuel pressure
I have a 2008 lnf with just bolt ons stock fuel system.
im on full e with a tune but i keep losin fuel pressure even when i was on e47 it would sputter at a high rpm and now at a high rpm it just falls on its face and sends me the code along with reduce engine power. Idk where to start besides with the HPFP but don’t want to throw my money away any ideas? Btw cr has 102k miles
Old 11-04-2018, 12:06 AM
tomj77's Avatar
What turbo? What kinda tune? If its running out of fuel up top you obviously need fuel mods. Definitely if ur over e47. Need opels and cam with bigger cam lobe for the pump. If ur on big turbo and trying to run e85 u will need lt1 pump
Old 11-04-2018, 12:42 AM
Badbowtie's Avatar
i have a stock turbo
Old 11-07-2018, 08:08 PM
tomj77's Avatar
im not 100 percent sure what u need on stock turbo....I think just the opels injectors.
Old 11-08-2018, 10:08 AM
armcclure's Avatar
i'm assuming you replaced the injectors/seals?
Old 11-10-2018, 08:18 AM
63 Nova SS's Avatar
You should have plenty of fuel running e47 at higher rpm. Don't even need opels for that. Sure your not getting spark blowout? Any misfire codes? I run e47 on a slightly bigger wheeled k04 and it loves it. Do you have a way of logging it to check and see what your pressure is dropping to?
Old 11-10-2018, 02:16 PM
Same here running e47 on a bigger turbo and dnt run out of fuel
Old 11-10-2018, 03:40 PM
Try the top of 4th gear
Old 11-10-2018, 11:18 PM
When the car runs lol
Badbowtie
11-05-2018 01:07 PM
Badbowtie
11-04-2018 01:39 PM
02-03-2017 02:17 PM
Nfamous60
10-09-2012 10:45 AM
Quick Reply: lnf Fuel pressure
