Porformence Problems
Old 11-09-2018, 10:05 AM
Luis Batres's Avatar
I have a 05 cobalt ss with 107000 miles and i just bought the car i went to Autozone to get is scanned cause the engine light was on and the codes that they read were
P0603- control module long term memory rest
P0017- crank shaft position senor
And im not sure if these code have anything to do with the car not allowing me to pass 80 mph because when im on the freeway and about to hit 80 the car starts to lose all of its power and i can press the gas pedal all the way down and it wont do anything and then it starts to say engine reduced power. Also im not sure if the guy tuned it or not cause i am pushing more than 12 psi like around 15 or 17psi please help dont be harsh im just a noob. Thank you
Old 11-09-2018, 10:13 AM
jdbaugh1's Avatar
Can't change the boost pressure with a tune on supercharged Cobalts. Only way to increase boost pressure is to change to smaller pulley on supercharger or introduce exhaust restriction. Post a picture up of your supercharger pulley and we should be able to tell if it is stock or not. If you have stock pulley and are pushing that much boost it isn't good and you may have a clogged cat.
People will have to chim in on the codes. P0017 fault can be enough to cause reduced performance on it's own though I don't know what the common associated failures are.
Old 11-09-2018, 10:29 AM
Ok and what about it not letting me pass 80 mph and my gas gauge if flip if that give a hint on whats going on witg my car
Old 11-09-2018, 10:38 AM
jdbaugh1's Avatar
Not sure what you are trying to say about the gas gauge but if your crank trigger isn't working correctly your ECU could go into reduced engine power just because of that. Could just be a bad ground, bad sensor, ECU or other things which people more knowledgeable with that code may be able to better help you with.
Old 11-09-2018, 01:40 PM
Sharkey's Avatar
wait, do you mean the gas gauge works backwards? as in when you fill the tank the gauge shows empty and when the tank is empty it reads full? that would be what happens when you put a 2006 or 2007 ecm in a 2005 car.
Old 11-10-2018, 12:11 AM
I have already bought a new crankshaft position sensor and put it on but after a while it came back on and yes to the gas gauge and how would i know if i have a differnt ecu/pcm?
Old 11-10-2018, 12:37 AM
Sharkey's Avatar
in 2006 gm changed the way the fuel sending unit works, it works in reverse of the 2005 car. when you swap the pcm between a between a 2005 and a 2006+ car the fuel gauge works in reverse. you dont really need to look further into if its been swapped, its obvious that it has if the fuel gauge works backwards.
check your blower pulley, see if its a press on pulley or if it has bolts in the front of it, and maybe a size. also check the injectors, if they are green and silver they are stock, if they are black and silver the are likely gm stage 2 42lb, and if they are all black they are 60lb or 80lb. knowing these things will give us an idea of whats been done. its likely not related to the problem but still can be helpful.
Old 11-10-2018, 10:55 AM
Old 11-10-2018, 11:02 AM
Old 11-10-2018, 01:07 PM
Sharkey's Avatar
so it has a stock pulley and stock injectors. seeing how much boost your making you likely have a clogged cat
Old 11-10-2018, 05:30 PM
How would i unclog the cat
Old 11-10-2018, 05:44 PM
Sharkey's Avatar
by replacing it
Old 11-10-2018, 08:40 PM
Can i just gut the cat?
Old 11-11-2018, 02:38 PM
Also what are somethings that will happen to my car to know for sure that it is the cat and what are something that will make my boost be so hight with a stock pulley and injectors?
Old 11-12-2018, 08:43 AM
jdbaugh1's Avatar
Remove the cat section and try to shine light through it
Old 11-30-2018, 11:16 PM
Ok i gutted the cat and it is doing same thing.
It only lets me rev it to 4000rpm and i lose all power when im i have foot all the way down on the pedal but still moves at a constant speed with the boost rising only no power
Old 12-03-2018, 07:45 AM
jdbaugh1's Avatar
Doesn't the boost meter rely on the MAP sensor? Could it possibly be reading wrong? I don't know if that is likely or not just throwing out ideas.
Old 12-03-2018, 11:26 AM
steelmesh's Avatar
Maybe the P0017 is caused by a timing chain issue like a worn tensioner or skipped timing gear teeth.
Old 12-03-2018, 01:19 PM
The p0017 was the cam senor which i already fixed
But can it be my bypass valve? And it started to make a whistling sound now
Old 12-03-2018, 01:21 PM
Can it be that my bypass it not opening open ?
Old 12-03-2018, 01:39 PM
armcclure's Avatar
jumped cam timing can cause high boost also, and would correlate with the p0017
Old 12-03-2018, 01:54 PM
thejoey12's Avatar
you may have fixed the cam sensor, but did you get the timing all lined up? i had this happen to me a few years ago and ended up bending a valve and blowing cylinder 3 out.
brandon lee perez
02-24-2014 04:44 PM
RockRobster
06-22-2013 04:30 PM
07SSYellow
05-19-2011 05:40 PM
chris88z24
12-29-2009 12:45 PM
cli3e0339384398jk
Canadian Mid West
18
04-28-2008 02:23 PM
Quick Reply: Porformence Problems
