Original Battery
Old 12-14-2018, 03:23 PM
SilverSS2008's Avatar
Original Battery
I am pretty shocked to see that the battery that came with my 2008 is still going strong. Anybody else still on the original?
Old 12-14-2018, 04:01 PM
My 07 still has the original battery. Idk how but the ACDelco batteries are tough.
Old 12-14-2018, 04:24 PM
ProfDNS's Avatar
Mine just died.
Old 12-14-2018, 04:29 PM
exninja's Avatar
the last time my car saw the stealership they killed it. it'd prob still be going otherwise. my autozone replacement is on year 5 now.
Old 12-14-2018, 04:42 PM
ProfDNS's Avatar
I'm thinking of getting that yellow top Optima battery.
Old 12-14-2018, 04:54 PM
Old 12-14-2018, 04:59 PM
ProfDNS's Avatar
Well, I want to upgrade my audio system so I figure the better battery should be able to handle it.
Old 12-14-2018, 05:01 PM
Thats not a bad reason
Old 12-14-2018, 05:51 PM
My car still has the og but I havent started the car in over 2 months since no trans so let's see if it will come back to life after
Old 12-15-2018, 07:58 AM
I had a yellow top Optima in my Camaro and that one lasted me 12 years. I believe they got bought out by Johnson Controls though and the quality has gone down significantly. Nice to see others have had such good luck with the factory battery as well!
Old 12-16-2018, 06:18 PM
chris88z24's Avatar
Having the battery in the trunk and not under the hood is what allows them to last a long time.
Heat kills batteries, not cold weather.
Old 12-16-2018, 07:41 PM
ThePanduuh's Avatar
I just replaced mine. Felt like it was getting weak and didn't want to get stranded. Original battery from '09. Found out the only cars that use the battery we have is cobalt, HHR, and corvette. $128 from my stealership and I won't have to worry about it for another 10 years.
ACDelco 90PS is the part number
Snail_SS (12-16-2018)
Old 12-16-2018, 07:58 PM
I will probably buy another acdelco if I need one
Old 12-16-2018, 08:06 PM
ThePanduuh's Avatar
I was in your situation. LDK swap took a month, car sat disconnected. Battery needed help starting, ok. Then it got down to 20F and lights started to look dimmer and cranking seemed a little slower. Figured it's cheap insurance so I don't get stuck somewhere later. Might as well chuck it on a trickle charger or call your stealership to see how much it costs.
Old 12-19-2018, 06:47 PM
cobaltssdude420's Avatar
Yeah my stock one lasted 7 years
Old 12-27-2018, 10:17 PM
tomj77's Avatar
pile of crap battery. mine lasted maybe 3 years.
Old 12-28-2018, 10:00 AM
Kolt's Avatar
My 08 ss is on its original, keep the trickle charger on it when she is put up. The ls is on its second battery, it started getting weak about 3/4 years ago so I played it safe and got a new one.
Old 01-01-2019, 03:53 PM
Should grab a capacitor if your getting subs
Old 01-01-2019, 03:54 PM
My stock one lasted like 6 years
Old 01-03-2019, 11:22 AM
06cobaltss/ss's Avatar
when mine goes i will replace it with a delco from the dealer. previous owner put a cheep battery in mine.
Old 01-03-2019, 02:03 PM
Kolt's Avatar
I will probably go with the same duralast gold I went with on the ls. I found a oversized battery with higher cca that fits in the tray if you cut off the plastic mounting lug on one side of the battery. Works great, I rarely ever drive the ls and don't have a battery tender on it. Never had to jump it off either and it has sit up to 6-7 months a couple times
limptera13
08-11-2016 02:40 PM
Sachemhockey44
09-01-2013 11:35 AM
SKY888
03-09-2012 06:08 PM
Modernceo
Modern Performance
14
02-08-2012 08:16 PM
portergraph
12-04-2006 11:44 AM
Quick Reply: Original Battery
