Before my car pops out another axle
Old 04-04-2019, 11:05 AM
Z07Brandon's Avatar
What should I lookout for? Car is lowered on BC Coils, is that what keeps causing the passenger side to pop out? Car has stage 1 zzp axles. I've noticed it pops out when turning/or coming out of an incline.
Old 04-04-2019, 11:26 AM
do you have rotated mounts?
Old 04-04-2019, 02:35 PM
Z07Brandon's Avatar
No, car has stock mounts.
Old 04-04-2019, 03:32 PM
Rotated mounts should fix it.
Old 04-04-2019, 08:04 PM
Z07Brandon's Avatar
Not to sound dumb, but what do those do? I read it helps with, "coil bind". But not exactly sure what they mean by that.
Old 04-04-2019, 08:43 PM
Changings the engine rotation (front to back of car) to align the axles so they are closer to neutral instead of at an offset already.
Old 05-20-2019, 03:28 PM
Z07Brandon's Avatar
Been busy with life and working on my other cars. 96 lt4 vette and 03 xjr r1, if anyone cares.
Anyways, should I buy stage 1 or stage 2 rotated mounts? Only asking because ottp doesn't answer my calls/voicemails or emails.
Old 05-20-2019, 03:59 PM
I wouldnt buy anything from a company that doesnt respond to calls or emails.
https://zzperformance.com/collection...#productOutput
Z07Brandon (05-20-2019)
Old 05-20-2019, 08:58 PM
63 Nova SS's Avatar
On a side note, if you have a need for a spare lnf axle let me know.
Old 05-20-2019, 09:29 PM
Z07Brandon's Avatar
Thanks, but my car is an 05. So LSJ
Old 06-22-2019, 12:58 AM
Z07Brandon's Avatar
Installed front and rear rotated trans mounts weeks ago. While putting the axle in, I forgot to put the brake line on first. So, instead of having to remove the axle, I loosened the brake nut on the caliper. Took the car out for a short drive. Everything seems fine, except for 2nd gear shift. When you let out of the clutch pedal once you've gone into 2nd, the car jerks. Like when you are first learning to take off in a manual.
I know these cars share the same reservoir for the brakes and clutch. So with me loosening the screw on the caliper, does that interfere with shift/clutch function? Clutch feels the same as always, and bite at the same spot as always.
Twoozofjuice
09-11-2012 07:50 PM
06supernightmare
05-24-2012 08:28 PM
LSJ
04-20-2011 12:27 AM
willdrew
10-08-2010 12:23 AM
scotch89
01-06-2010 09:01 PM
Quick Reply: Before my car pops out another axle
