Front left clunk clunk
Old 04-14-2019, 06:39 PM
DeanSsspsh's Avatar
I was under the car yesterday changing the oil & ran into this. I'm not sure what this part is called or what i need to do to fix it. I can feel the car clunking a bit when making a u turn. Thank you in advance for eveyones attetion on this matter.
Old 04-14-2019, 08:46 PM
ProfDNS's Avatar
That's your outer tie rod bushing. That thing is shot.
Old 04-14-2019, 11:36 PM
DeanSsspsh's Avatar
Ok Thank you kind sir. That's what i needed to know. Gonna have to read up on how to replace it & what it will cost. I appreciate you
Old 04-15-2019, 12:50 PM
exninja's Avatar
It's pretty simple. Borrow a pickle fork from local auto store (since your outer tie rod end is shot anyways). Remove nut. Use pickle fork to pop the stem out of the knuckle. Unscrew from inner tie rod (hold the inner with a wrench while you turn the outer). Screw on new outer. Insert into knuckle. Torque to correct value. Insert cotter pin into castle nut. Get an alignment. Profit.
If you still have noise after that, it's likely either your sway bar bushings or sway bar endlinks.
Old 04-15-2019, 01:07 PM
DeanSsspsh's Avatar
Awesome man! Thank you. I can do that. Now the part im replacing. Is that just a tie rod bushing?
Old 04-24-2019, 07:36 PM
DeanSsspsh's Avatar
Esc flash after outer tie rod install
I replaced my outer tie rod today without any problems until i went for a drive. NoW when I'm in boost the esc flashes on the dash. Why is this happening?
Old 04-25-2019, 06:54 AM
C0balts5's Avatar
Is your steering wheel off center?
Old 04-25-2019, 07:40 AM
DeanSsspsh's Avatar
Yessir! Steering wheel is off center. I think when i tightened the outer tie rod end on i spun the whole tie rod to the left a lil bit. The outer the rod was not fixed to the wheel when i futzed with it causing it to rotate right when i tightened.
Old 04-25-2019, 08:39 AM
C0balts5's Avatar
Get it aligned and your light will go out. The crooked steering wheel is throwing off the steering wheel angle sensor for the esc "electronic stability control".
Old 04-25-2019, 01:28 PM
DeanSsspsh's Avatar
Alright then. Thank you guys
talkeddelta8
11-14-2014 12:37 AM
Sachemhockey44
09-21-2013 10:18 AM
rivaladore
04-15-2013 12:01 PM
Michael Kenter
09-10-2012 01:49 AM
klutch814
06-04-2012 01:15 PM
Quick Reply: Front left clunk clunk
