No start but has power.
A couple days ago for the first time my cobalt (2009 lnf) tuned with Boltons, started to act funny. My airbag light came on and the car wouldn’t start. Turned the key and like a dead battery, but a couple warnings came up and my rpd wouldn’t turn on. So I got warnings for “power steering” “service airbag” “service esc” and my wipers will only work on high speed now along with the Little lock and car in the corner of display. After a couple try’s of starting. Putting key in and out it will prime fuel pump and rpd will turn on, and will start up easily. Runs and drive perfectly fine. I’m going to check for codes tomorrow, but is there anything specific I should look for?
I took the fuse box out, cleaned all the connectors, cleaned each fuse individually, then took off the bcm connectors on the passenger side fuse box and clean each out those connectors and fuses individually, still have a solid theft light and will start the odd time, I’m thinking of just taking it to the local gm dealership
GuardLife
05-15-2019 11:42 PM
jon_0_3
10-14-2013 07:32 PM
