Lsj to l61 issues
Old 07-16-2019, 07:10 PM
hatchbackbub's Avatar
Lsj to l61 issues
I bought a 2006 SS project. The LSJ was not in it for some reason. A 2007-08 L61 was put in by previous owner. The car will start and run (not easily), but lacks serious power and only revs to 1100-1500 RPM. I know this has been done before, but this is my first cobalt and in need of some guidance....
Old 07-16-2019, 07:51 PM
Sharkey's Avatar
the crank trigger wheel is clocked different between an lsj and an l61, and im not sure if the 07/08 l61 cam trigger wheel is the same or not.
as far as i see it, you have 2 options, and one im not even sure works. you can either find an lsj or a saab b207 for it (essentially the same long blocks), or get a 2007 2.2l wiring harness and computer, and there is no guarantee that will work correctly.
Old 07-17-2019, 08:30 AM
jdbaugh1's Avatar
Doesn't the head on the 07/08 also have VVT?
Old 07-17-2019, 09:34 AM
Kolt's Avatar
Not for l61. only le5.
His only realistic option at this point are to get a lsj setup. Swapping to a full l61 is going to cost more not only in all the wiring and ecm but also a lot of programming and tuning since he has a ss programmed bcm and a ss transmission.
edit: when you say swapped to l61, is the supercharger stuff from the lsj still there or is it a full l61 setup?
Old 07-17-2019, 09:38 AM
Yeah your timing is probably like 20-30 degrees off. I cant remember how much, but the lsj and l61 crank trigger wheels are clocked differently.
Foximus
06-24-2015 07:12 PM
CptProzak
03-11-2013 11:08 AM
Allgood Customs
10-09-2012 02:31 AM
mmcgee123
01-20-2011 04:19 PM
untamedsilverLS
2.2L LAP Performance Tech
06-08-2010 10:48 AM
Quick Reply: Lsj to l61 issues
