- wideband question
- pid af error help plz
- Back from Tune Time Performance in NJ...
- Tuning for MPG
- need a tune in lower wisconsin
- 2.2L Tuning Rant...
- knock
- 2.0L s/c upgrades
- HP Tuners
- Tuner in Newfoundland
- Stage 2 42.5 lb injectors Question
- just an idea
- Cylinder Air Mass with 2.5 Pulley
- Can I replace the Stock O2 sensor with a wideband?
- LC-1 Question
- MAF Tuning Help
- tuning in manitoba
- HP question
- 2.4 ecm swap?
- my car is running lean. do you want to tune it?
- HP difference in a 93 vs 104 octane tune
- First step in tuning my S/C setup?
- garrett turbo alpha..
- e-Manage Utimate
- Auto LE5 help
- Tuning for cams...
- Lc-1
- Will be tuning in the Philly area during President's Day weekend and week.
- Tuner In Miami
- 2.2L Tuning: Powertrain Control Solutions
- confused about ve n pe
- Lean spike just before entering PE for a split second
- Need some desperate help finding a tuner(HPTuners)
- Anyone have a 2.2L File for AEM?
- aem f/ic on a 2.2
- changing a tune
- Check out my tune.....
- Problems with tuning
- PCMForless
- tuning for meth?
- PAGING: WITT, come inside
- pcmforless or vector motorsports
- IAT2 numbers, whats normal??
- LTFT and STFT range
- shift light
- HP Tuners Help Please!!!!!!!!!!!!
- EFI live tuning
- Pulley sizes
- Mini AFC 2.2
- Mini AFC 2.2
- Some advice here plz!!
- HP Tuners
- interesting
- Need Help...Nothing Huge just a tuning problem
- 05 Cobalt 2.2L AEM fuel/ignition controller
- De-tuning a car
- SJSchafer Number
- HPtuner question
- Tuning Question with HPtuners
- PCM Swap?
- 2.4l boost tuning...is it possible?
- Gm School
- Any one who tunes on now
- gm stage 2or3 tune
- Need feedback on my tune
- snow t00n
- going lean then totally dying. HELP!
- Available Tuners & Locations
- Part throttle tuning question
- quick HP tuner question
- bosch wideband sensor
- tuning thread
- interceptor readings discussion
- Noob question
- adding extras
- need help.
- Tuning Books
- p0069 help!
- for those who go to the track
- gm stage 2 tune
- NJ and Eastern PA Cobalt Owners
- Wideband Error
- Wideband pegged rich in boost, and only in boost
- I need a volunteer :)
- Nice write-up on tuning/detonation
- Where to get Stage 2 Kit and does it have to be installed at the dealer?
- 2.4 LE5 Tuning FAQ
- Husky Fuel = Lean!
- MAF Tuning & a quick ltft question
- AEM Wideband and HPTuners
- Stage 2 Supercharger Kit
- Meth Tuning
- HP Tuners 1-2.5 bar E38/E67 ECM's features
- Wierd lean idle and cruise
- 2 questions : P0103 and IFR table for 42 lbs injectors
- indiana tune
- OH guys where to get tuned?
- logging
- Jet Performance Chip Questions
- 2.4 f/i Tuning Question?? Power Enrichment
- GM stage 2 reflash SUCKS!!!!!
- Setting up Injectors??
- 87 octane winter tune
- custom tuning in so cal
- 3 bar tune on 2006 Cobalt??
- HPT pro + LC-1 logging
- Jet Performance Products for Cobalts?
- Logging Wideband??
- 2.4 Supercharged log file
- tuning a stock ss/sc
- 05-06 crank trigger set-up?
- 10.0:1 w/60lb Tune requests
- Air Fuel Ratio Commanded Hi Res
- AFR question w/tune
- VCM scan problems
- Pay for a tune
- what to do with hptuners?
- TX/NM Tuners?
- IL Tuner?????
- Tune needed...
- I need a tune really bad!!
- Question abou timing advance ...
- Central Ill HP Tuners?
- Config file help
- 10:1/42.5#/3" tune???
- cell of 36* at .92g/cyl and 5888rpm
- hpt tuners in pa
- connection issues 05 ss
- COT and DFCO?
- HP Tuners
- scan for knock?
- Big problems with knock
- Michigan tuners
- New tune or is this normal??
- i need a tune
- Hp Tuner ?
- Help I Need A Tunner!!!
- AEM Uego or Innovative lc-1?
- Tuners: Check out my log
- I need a tune
- best wideband?
- Jmc007 First log (Untuned).
- Question about siemens 60lb'ers
- Want to install my wideband.
- lost tune
- Which ECU's are supported by HPtuners?
- Quick question
- Ipw Pid ...
- few questions to see if anyone knows the answers :)
- Need some pointers
- Need HPtuners help
- I assume i am okay with this 2.80" pulley?
- Info about dynoing a car.
- 14.9 AFR!! Where is the ECU hookup so I can send narrowband?
- Please Help
- HPtuners program
- Anybody with Credits Willing to Help?
- HPTuners Question ...
- too much timing?
- Effects of ambient temperature on tuning..
- Hptuners credits?
- code p0300
- your timing.
- tuning a gtp with hpt
- VE Tuning in open loop....couple newb. questions
- IFR delema
- HPtuners-PRO or Standard
- VE Tuning how to
- Anyone dyno tune in louisville?
- Just got my 2.85 pulley!
- Hp Tuners for Sale?
- Oil Pressure
- What cables come with HPTuner PRO ?
- Looking at a wide band
- Anyone sending narrowband to ecu with LC-1?
- Need help with incomming Vector tune
- Dyno
- setting up hpt to read KR?
- VE tables question.
- Aem F/IC
- tuning in jersey?
- All you pro tuners...
- how do you like your hptuners?
- Which wideband do you NOT have to weld a bung
- 1st SETUP injectors (flowrate, rate modifier, Min pulse width, PW adder)
- Tuning for 60lbs siemens injectors
- ZZP pcm added 7/27/07
- Trying to figure out what to get.
- All This Talk About Tunning! Post your...
- tuning for 2.2? my auto performance shop says "yes!"
- Tuners in the Tri-state area?
- where to begin tuning the 2.4 for boost
- timing and you
- For serious tuners ...
- Lower the boost at high rpms ...
- Safest yet most aggressive pulley size for 52 lbs (550cc)
- Need Help
- Tuning in Georgia?
- fuel tuning, something to think about
- J & S Safegaurd
- Snow Performance meth kit tuning with HPtuners?
- How to scale for bigger injectors in HP tuners
- Anyone Around Cincinnati w/ HP Tuners Credits?
- apexi s-afc neo????? help
- turbo question 4 tuning
- anyone with hptuner credits
- I need the VE table for idling
- Those who are good with CEL's
- ecm changes.
- Hp Tuners stg 2 tune?
- Getting Started with HP tuners....
- Re-flashed PCM worth it?
- Computer Chip in 2.4
- Frequently asked HPTuner questions
- hptune
- Hp tuners Delete rear o2 sensor
- HPTuners Torque Management and Blown Tranny's?
- the acclaimed tuning by SCT
- Anyone have a good tune for 42.5lb'ers and a 2.8" pulley?
- HPT/Injectors Question
- HP tunters in midwest
- Wideband O2 controller shoot out!
- idle mixture
- Innovative PCM
- air/fuel ratio with exhaust sniffer
- wideband used with HPT Pro
- Primary VE Table.....
- Show me your PE table!
- 2.8 and 60#s Basic map
- PE tables
- timing verdict
- Question about the vector tune
- Anyone tune in TX
- New HP tuner in New England
- I need help with a tune!
- Tuners In Central Florida?
- HP tuners North Jersey NYC area
- boost limit on 07
- HP tuning....stock and stage 2...
- 60lb Injectors?
- maf
- Convert to Speed Density
- timing limit on lsj
- Lean in low gears
- S.T.F.T. & q's about tuning (technical)
- 2006 2.4 cobalt
- Need GM Stage2 Tune or better
- LE5 Injector duty cycle
- tps ?
- Tuning For Meth
