- Tuning direction
- HPtuners in upstate NY?
- EFILive
- New to HP tuners
- 6olbs inj., anybody have a good tune for them?
- 60lb flow at 43.5 psi
- question
- improvement with gas mileage
- 06 VS 07 ss/sc cars
- Find a tuner
- Reflashing another cars PCM with HPTuners in my car?
- quick question
- sorry for the stupid ?
- 07 ss/sc with 60's
- MAF histogram help.
- I need an HP tuners tune.
- AEM Fuel/Ignition Controller
- PCM relearn question
- car doin some PRETTY NORMAL stuff
- South Jersey People, Anyone Want to Split HPTuners?
- Blow thru Mass air flow?
- New to the SS
- Tuning?
- mass air hp tuners
- Uh huh
- HP tuners in mass
- Could HPtuners fix this?
- any hptuners people near me?
- No Cat tunes
- Fans desired % vs AC Pressure?
- Cooling Additive Comparison...article by Turbo Mag
- Need Help Tuning In Chicago!
- injector flow rate and injector offset.
- Need software
- Tune in New Orleans? anyone know where or can
- any norcal tuners
- Tuning in Atlanta
- Wideband installation
- Tune in Michigan
- Richen Those Tunes!!!!!!!
- noob needs a tune
- I need a Tune in Florida..
- Stage 1&2 Base Map For HP Tuners?
- show me your PE
- Best Possible Tuning Software
- No Cat, what codes to expect?
- Anyone in my area with hp
- Diablo Sport tuning is Offical!!!
- Please Look Over My Tune
- How to turn off CAT OTP w/hpt?
- PLX SM-AFR: Best budget wideband?
- Changing AFRs.
- Looking at Intense or getting hptuners
- HP Tuners ?
- GM Tuning Question????
- What Gear To tune in.
- What you running for timing on 2.5-2.6?
- Anyone know a good tuner?
- "Tweaking" Stage 2
- Too much timing????
- hey everyone i have a question about tunning
- Who does tunnign in Ontario.....
- Aeroforce Gauge capabilities
- Anyone max out 60's?
- fuel pressure
- GM Service Tech 2.2 Tuning!
- GMPP Stage II Question
- IFR for 60's
- Best way to interface
- Needed .hpt file for 2007 GM stage 2
- Apex'i AFC
- ?Tuning questions?
- New Tunning Soution for Ecotecs??
- maximum safe spark dwell
- hp tuning not reading vcm
- Fuel Injector Duty Cycle Calculator
- cool trick with fans in HPT
- Very newbish question :(
- Datalogging Woes!
- 2.8" and 60lb Injector Tune Needed
- VE tuning questions
- help
- ANNOUNCEMENT: 2.2 Tuning. Please read
- HP Tuners and the factory warranty?
- What problems am I gonna have to overcome on tuning my 2.4 for boost?
- stock 05 tune?
- Timing
- Upgrading HPTuners and using pervious versions files ?'s
- 2.6" pulley and 60lb injectors tune
- When you're logging in HPTuners
- SD all the time???
- HP Tuners Question
- HPTuner in Tampa Bay Area?
- tuning help
- Tc
- south fl hp tune owners
- In need of 2.8 w/ 60's tune
- Any Suggestions for MAF-T Settings?
- Afr goes into the toilet
- thinkin of useing piggy-back need help
- 06Blackg85ss tuned my car!
- HP tune question
- Modding, Tuning & Dyno-ing in MTL?
- anyone know?
- Hptuners...do you reccomend it for someone with no tuning experience?
- need tune help now!!!
- Different kind of tuning question...kinda.
- Universal Injector spreadsheet
- Help me reduce knock.
- Finally gave the car some HPTuners loving!
- Son of a Bitch!!!
- My car doesnt want to work with me!
- desktop dyno program
- Help
- Injector offset vs fuel trim
- put 60lb injectors in the car.
- Life after 215kpa....
- 2.4 tuning
- Brought new Wideband guage.
- Brave soul wanted with HPTuners
- P0171 Lean code on Stock SS..can it be fixed with HPT?
- CA Stage Upgrades
- Wibeband a/f ratio readings on stock SS/SC..?
- im losing my mind
- Got "Caught" Tuning
- intake
- Late model 2.4 cobalt or Ion file needed
- Fuel System 101 FAQ
- Possible Fuel System FAQ
- HPT VCM Suite 2.1.16 & Windows Vista - Critical Read
- Can Some One Help Me With A 2.7 And 42lbs Injector Tune?
- Dyno or tuning shops in Western Pa
- HP Tuners VCM Suite v2.1.16 is Now Available!
- Is 2bar map tuning possible on LE5
- 2.8 and 60# injectors.
- SO I tuned Glockglades car.
- Diablo Sport tuning for the 2.2 & 2.4
- APEX-i SAFC II???
- How much max timing you running?
- Need Tune for SS/SC with only 3" pulley
- P0128 Cel??
- Quick question for those with hp tuners
- My IDC's at 16PSI with a 2.8" and 42#Injectors
- 60# Tune
- need someone to help me out....
- Stage 2 vs Stock Comparison
- Replacement Bosch Wideband Sensor
- WTF!?!? PE Help!!!
- How to use the credits I just bought.
- Canned Tunes Vs. Hp Tuners?
- HP Tuners has added a few more demo's
- Spark Dwell?
- HP Tune Question?
- Car won't start after HPT flash
- Stage 3 PCM?!?!
- HP VCM Scanner program questions
- when should you get tuned?
- HP Tuners question?
- SCT Rides to the rescue of 2.2 owners!
- This Tune RUNS LEAN...RIGHT!?
- Can HP Tuners tune a 2.4 for boost?
- We Need Your Vote
- HpTuners
- HPTuners config repository
- Need PCM Diagrams
- What to change to get rid of P0102 code?
- What computer port does HPTuners cable use?
- update on custom tune from steeda.
- Looking for an 05 SS gm stage 2 hpt file.
- How the hell does HP Tuners work?
- Using E-85. 100+ octane for less than $5 a gallon
- Timing?
- Newb, Changing Timing
- HPTuners; Noticeable Performance Change?
- Anyone get this high?
- I need some HPTuners files
- anyone in the northeast area know where i can go to get tuned?
- HP tuners for the 06 2.4; worth it?
- Converting Injector Pulsewidth to Duty Cycle
- Custom PID's
- My Tune, opinons and help wanted/needed
- Getting Knock Retard.
- Where to go?
- just wondering
- How lean is Safe???
- Share your HPtuners log screenshots...
- MAF Frequency / Tuning Questions .... READ ME! Need help!
- New PCM requires more credits?>
- 2005 SS OEM Tune please
- car falls on its face while idling
- 2.2 Manual Thought
- tunetyme claims 16whp 12whtq u agree?
- Ecotec engine management summary w/ PinOuts
- 2.2L 05 PCM and 2.2L 07 PCM Compatible?
- 2007 GM Stage 2 - A Thoery
- WTF?? 4* of knock in 4th?
- Anyone with the new Stage 2 flash in their car and HPTuners??
- UMI Racing Standalone
- these mail in tunes that our out now?
- Who wants Custom HPT Tunes??
- MAXXED OUT THE 42.5s with STAGE 2
- hp tuners& Cams
- Tuning section is now OPEN
- Amazing reflash results.
- Power Enrichment with HP Tuners?
- hp tuners..
